Dimmer wheel stopped working - screen and instruments
PMantle
I don't know if related, but I just had to change my truck battery. After doing so, the roller/wheel no long has any effect on the instrument or screen brightness. I tried looking at the settings, and yes, I can adjust with the plus minus, but I really want that roller to work again. Any ideas?
vincentw56
How long ago did you change your truck battery? After disconnecting the battery, it can take around 6 hours for everything to come back online. This is normal. If it has been longer, then maybe the switched stopped working.
PMantle
I figured it out. Prior to this, I had never really fooled with the settings. After the battery change, the setting was set to manual. The wheel doesn't work on mine unless set to Auto. This thread can be closed/deleted.
