Ride Comfort 18" wheels Vs. 20" wheels
DeanM2
I really don't like the look of the 20" wheels that came with my truck. They are all black, which I hate, and I don't like the look of "big" wheels. So I want to go with 18" wheels.
If you have some relevant experience here, don't the 18" wheels, which result in more side wall length, result in a somewhat "better" ride? They have more sidewall length which should result in more ability to absorb bad road surfaces. Correct? Meaning, all other things being equal; same tire brand and pattern and size, shouldn't the 18" wheel result in a better ride?
If you swapped to an oem 18 with oem tire. It would be little more floaty. You would loose a small amount of handling as trade off.
If you make an other changes though the results can go the other way. Offset, weight and width would need to be close to your current wheels.
All else being equal, the 18" wheel/tire combo will be a little heavier and softer and transfer a little less of the sharp edges of the road to the suspension, but it's not much. Also maybe useful to some, the sidewalls will tend to stick out past the wheel a little farther, maybe prevent some curb rash.
I know it’s not fully apples to apples but I went from 37s on 20s to 37s on 18s and wow the 18s ride so much better. They absorb bumps a lot better and feel softer
Probably why the rebel/TRX is on 18s from the factory. Those LT tires have much stiffer sidewall.
That is what I was expecting/hoping to hear. :)
