Cheers to four years
Congrats my friend. Me too. However, it is mileage not time. Go here and get setup and it will tell you when to service everything. It will record all of your dealer work automatically and you can manually upload any addtional work. It has your whole build and owners manual on it. A great app.Owner Vehicle Dashboard | Official Mopar® Site
I've had my 19 Rebel for four years now and curious if I should do any extra maintenance to her like change diff fluid or pump some grease into fittings.
If you have grease zero fittings and haven't added any grease to them, you are already behind on maintenance. You should be greasing those areas at least every oil change. But I don't know if any factory installed grease zerts on these trucks.
Most maintenance is tracked by mileage. Referr to the service schedule in your owners manual. But transmission should be done at 60k miles, even though owners manual says its lifetime fill
Thanks. Looks like I was already signed up and everything looks good.
Congrats I'm on my 4th year almost exactly right now as well.
By now you definitely should have done:
- T-case fluid change/inspection
- Front diff oil change/inspection
- Rear diff oil change/inspection
You are probably right around the need for:
- ZF Trans pan/filter/fluid change if at about 60k
I cannot confirm the grease fittings.
Dealership changes the oil, so I wonder if they have checked. If not, I can replace the fluids myself.
I'm at 62k miles, so i might knock this out this weekend.
