Oh and I also found out when your headlights are on and you activate the turn signal, the damn fog light on that side comes on to help illuminate the corner! I like it.
Or just keep your dog lights on all the time
Dewey
WI
I found that to be a very annoying feature so I disabled and keep the fogs on at all times even when using the brights via Tazer.
If you keep fogs on all the times there is no need to disable it
Dewey
WI
I am pretty sure the fogs shut off when the highbeams are engaged. With the Tazer DT, you can disable that from happening. The fogs will stay on with the highs. I do it on mine.
Correct
Burns1200
Ontario Canada
Can be done with Alpha too. Fog light dropout enable/disable. I've done it myself on a few of my trucks
But that's not what he said, he said he disabled the feature of them coming on when turning. All I said was if he keeps them in all the time there is no need to disable that feature
Grape_Ape
But there is. I keep fogs on at all times but I don't have them on with my brights. When my brights are on and I'm turning my fog for that side will illuminate. I haven't turned fogs in permanently with alpha because I prefer for people to know when my brights are off since it's standard for them to drop out with high beams.
BUT THATS NOT WHAT HE SAID. And not even what was being discussed. I understand the difference.
I. DON’T. KNOW. WHAT. WE’RE. YELLING. ABOUT.
People that keep replying to me about a setting that wasn't even being discussed as if it was the solution to the issue, but has nothing to do with what was being discussed.
boogielander
Did this over the weekend:
Mopar window visors. Now I can run starlink or charge my EcoFlow with solar/ household outlet without leaving the windows open all the way down overnight. Great for keeping critters out.
No, window is fine. It is reflection of my neighbor's tree on my tinted window.
Is the weatherstrip close to the B-pillar suppose to behave like that? I've tried to install it 10 different ways and every time it's the same.
Redz72
Langhorne, PA
My EGR in channel’s did the same thing with the weatherstripping. It’s been a few months and have no issues so far. I think it’s just the way in channel’s sit. BF9EB1C8-27AB-4F52-B0F5-5EBB247CF3AE.jpeg
Mine are slightly like that, but not as bad. They are US Visors off Amazon, but they arent sold anymore PXL_20230911_221326101.jpg
boogielander
