Looking for minimalist fender flares.
Jammer22
I did my best to search the forums but could find an answer to my question..... which is does anyone know of a manufacturer making a basic minimal fender flare? Something around 2" in height. I'm looking for protection from stone chips as I live rural on gravel roads. I have a 2019 Big Horn. Thanks in advance for your time. Cheers!
vincentw56
That's what I have on mine. Just the right size.
JRD
Get some factory flares
I found the factory PN online, but do you know why there would be 3 part numbers for left front and 3 for right front? Same thing for the rear. Not sure if there is any easy explanation or not, but I searched based on my MY
Part numbers are different for different paint colors because you can get them color matched to truck.
JRD
Not an easy mod. You either have to cut all the studs off the flares or drill all the holes in the fender. The ones I listed look factory without the hassle. That's why I went with those.
if you cut the studs how do they adhere to the fenders? im assuming you could remove the push pins in the wheel well and have them go through the fenders are the flares? not sure if that would have the rigidity or not
vincentw56
The bottom bolts into the same place that the inner fender liner does. And then you could use some 3M double-sided tape to hook them on. That's what others have done. And that's how these aftermarkets work too. I've had mine for 3 years now and they still look good.
DeanM2
I am looking for the same thing for my 2023 Big Horn. The Mopar fenders look nice, but have a Mopar price. I also found them from "Lund". They seem to have a very easy install, and I think that is what I will probably go with.
2020GCM
I have these as well, paint match was perfect
JRD
Do you have any photos of these? $1k is kinda steep relative to the OEM which are like $200 I believe
vincentw56
$200? For 1 maybe. No way they are $50 each. Maybe I'm wrong, but I can't see it.
vincentw56
Here are the ones on truck.
vincentw56
unless i'm looking at the wrong PN theyre $70/ea
Can you send me the part number? There should be 2 part numbers or 4 maybe. Are they painted? If so, then there is probably more than 2 or 4.
JRD
vincentw56
here is the link for the flares, theres a number of part numbers but i cant find where it says what color. i cant imagine theres many other options aside from color?
5YL27TZZAD​
Well, I'll be. I never would have thought they would be that cheap. Guess pricing depends on color too. But still.
The color is colded in the part number.
JRD
i just googled my color code (PXJ) and i don't see that in any of the PN's with that code
is it not offered in my diamond black or am i missing something? also, i think a lot of the parts went down. when i was researching some other mods the prices dropped quite a bit from the rates they were listing in the threads vs todays rates.
