I don't believe there is any rubbing, I have not got under to look. I personally would not like to go wider myself. My intention was to add Bilstein shocks to level it, but of course Amazon sent the wrong shocks. Basically they are one size bigger over stock.did you have any rubbing? curious if you had to do any trimming or not.
do you think you could have gone wider without interfering with UCA?
I kinda tried to do this a long time ago. Every time I hit a hard bump the fender would bang on the taller tire. It was not pleasant. That is what introduced me to Bilstein 5100's. Not for the ride so much but just to give me a bit of clearance. Your mountain trails get really rutted out. You may want to consider staying with your Bilstein idea.I don't believe there is any rubbing, I have not got under to look. I personally would not like to go wider myself. My intention was to add Bilstein shocks to level it, but of course Amazon sent the wrong shocks. Basically they are one size bigger over stock.
Thanks @H2OMAN, I plan on going with the Bilsteins probably in December. We're leaving on a three week trip October 2nd for a trip to Mississippi. They will have to wait until I recoup some funds.I kinda tried to do this a long time ago. Every time I hit a hard bump the fender would bang on the taller tire. It was not pleasant. That is what introduced me to Bilstein 5100's. Not for the ride so much but just to give me a bit of clearance. Your mountain trails get really rutted out. You may want to consider staying with your Bilstein idea.
I got these installed on my 2020 ram. I wanted the Discovery 4s as they have excellent reviews. But I could not get the 4S anywhere so all I could get was the XLT's. The XLT is a heavier tire and is for heavy loads like HD trucks. I figured the heavier tire would not matter but I found my gas mileage got worse and the ride was much stiffer due to the heavier tire. I don't tow much heavy loads so I think they are overkill for me. When I go to get new tires I will getting 4s or K02's.Got the Cooper Dicoverer At3 XLT's 275/70/R18's installed today. Amazon sent the wrong Bilsteins, so no level at this time. Kinda like the way it looks as is. View attachment 165363 View attachment 165364 View attachment 165365
If I didn't tow a travel trailer, I wouldn't need the E tires. The rear felt just a little squerly with the stock Goodyear's. I really don't need 3peak tires were we live either, it is what it is.I got these installed on my 2020 ram. I wanted the Discovery 4s as they have excellent reviews. But I could not get the 4S anywhere so all I could get was the XLT's. The XLT is a heavier tire and is for heavy loads like HD trucks. I figured the heavier tire would not matter but I found my gas mileage got worse and the ride was much stiffer due to the heavier tire. I don't tow much heavy loads so I think they are overkill for me. When I go to get new tires I will getting 4s or K02's.
