Under hood weatherstripping push pins? Help?
19RAMSRU
Stillwater mn
Where the heck do I find these...
Thanks!
Lablvr2
If you need to order more take them to your local dealer and they should be able to match them up.
79 300
A dealer will be your best bet for an exact match, but most auto parts stores have an assortment of replacement clips and fasteners. I often found something close enough or even slightly better than factory.
Goatmann
Florida
Thanks!
When you find them, please post a part number. I need 4.
I will be at my dealer one day next week, I’ll see if the part guy has a few,
How many do you need?
Electrical
Go to any online FCA parts source e.g. EastCoastMoparts.com
Find part. Open wallet. Easy.
Goatmann
Florida
Easy, you post a photo of a 2018 hood, no help sir.
I have looked and did find the seal but no listing for the push pins
Electrical
Only posted as an example for those not familiar.
So we wait for 2019's to come online. You in a hurry?
mikeru82
The Palouse
I2R
Here you go, I just ordered some of these myself...
I looked at those and went to my local Ram dealer. He said the only way you can get the correct push pin is to order the entire hood seal. The ones I posted are exactly the same as the ones used on the Ram hood seal work perfectly. Those are for the actual hood insulation. I
BobbyLeeSniper
Michigan
These will likely only come with the seal. I can try and pull a part number for the individual pin tomorrow.
mikeru82
The Palouse
Maybe he can't get them, but the ones I ordered from the link I provided were waiting for me when I got home from work last Friday. Not sure why he's telling you that.
BobbyLeeSniper
Michigan
So I looked it up, for OEM part from FCA, you cannot get the individual push pin. It appears the supplier doesn't even list the pin as an available part.
With that said, you can do like Mike did and order a similar push pin from else where. Or find one that fits the hole. It technically doesn't need to be that exact push pin
z0n3
@mikeru82 did those push pins you ordered actually fit and work? I need to replace some that I removed for a bug shield that I no longer use. These seemed to be the clips for the hood heat shield. The ones IR2 look like the ones we need for the hood gasket itself.
mikeru82
The Palouse
No, I misunderstood which pins the OP was asking about. You're right, the pins I ordered were for the hood insulator.
z0n3
All good!
@19RAMSRU did those Honda cowl clips work for you? I need like 4 of these things and don't want to spend $40 on a new gasket.
