Lift install issues 21 rebel
cskindt
SW IA
I definitely have a more stiff front suspension. Drop a clip? Something I can do??
Would you be able to post a picture of your truck on level ground from the side so that we can better see the effect of your lift?
Based on what you posted so far, I would drop the front end down by 1-inch and the rear to your tastes accordingly, if necessary.
Also remember:
  • lifting by spring preload (adjustable struts) reduces your rebound travel while increasing your compression travel. It shouldn't change maximum mechanical suspension travel, just where your truck rides normally. Practically you'll gain unnecessary compression range and lose, sometimes necessary, rebound range.
  • lifting by adding top-hat spacers above the struts maintains their rebound and compression travel ranges, but you still reduce practical rebound travel due to the maximum mechanical limits of your suspension travel. Your truck rides further down in its maximum mechanical rebound range.
  • Both methods above increase wear on CV joints because they are in operation farther from there 0° state.
  • There is no free lunch.
  • There is always a compromise.
  • You need a real lift kit if more than 3" is your goal (+2" on a rebel or truck equipped with ORP/ORG springs).
RebelJC
Also remember:
I will get those pics soon.
I figured there would be a compromise, I just want to minimize wear if I can.
I may take out the 3.5" in the front and replace with a 2" and leave the rear 2" where it is. That should give me a better angle in the front and still be 1" taller to be level.
jl13
boyle heights, CA
Also remember:
Would swapping offroad springs for non offroad spring do the trick for him. That would be a cheap solution to bring the front down 1"
theblet
Motofab spacers are like $60. He could just swap those to the 2”. Not sure how much springs are.
cskindt
SW IA
It might result in a loss of 1" of lift, but I would just swap spacers for shorter ones. It'd be less work and cost a little less.
Also, I think the off-road springs have a different rate than the non-ORG springs so they wouldn't match the rear ORG springs.
RebelJC
Also remember:
Here are the pics you requested. Sorry it took a while.
RebelJC
No problem.
Just by what I can see on my phone, I'd say the photos confirm that you're over-lifted by at least an inch.
Probably use this one.
RebelJC
That should put you back in the safe zone with a solid 3" total lift in the front.
You'll notice a better ride quality and the CVs will be relieved too.
If you want higher, get some taller tires. After that, you’ll need a lift kit.
So will the tires I have now still fit??
285/75
