Need 2 testers!
Ronkartz72
Louisiana USA
I think most of us on here have changed our own oil for the most part and know the problem with the oil draining over the steering. I have made a solution to this hopefully and would like 2 people to test this out on their next oil change and give me honest feedback. If 2 people will send me their address, I would like to send 1 of these for testing. I am new to 3D printing and this is my first go round with building something from the ground up. Thanks in advance guys.
raygun9
Pm'ed
Looks great!
Sent from my SM-G781U1 using Tapatalk
TittoPollito
Looks good man...I assume that is an FDM printer and not a UV resin based on the size. If you start producing these more frequently insure that the material is not going to be compromised by the oil. A lot of the prosumer material is not compatible with repeated petrochemical exposure.
MishMashRAM1500
Nice! I usually wrap a piece of tinfoil over cardboard and "make" a ramp each time but this would be nice to have. A permanent tool.
Looks a little tight. Is the filter able to be completely unscrewed with it in place? wonder how it would work with the larger SRT filter I use
Darksteel165
Massachusetts
Cool to see people can just 3d print innovative things these days.
Looks to be a little short for the scoop, maybe a little longer or even better able to connect a piece of tubing and throw a clamp gently over it like a funnel.
I just got my oil udder XXL in today, it fits the SRT filter on the truck currently (very tight on the side between the lines), i'm not due for a change for a while so I don't know how well it will work.
Doesn't look like this leaves enough space to be unscrewed completely with this under it.
kdoublep
USA
I cover it with a silicone baking mat I stole from the kitchen. Wife is still looking for it.
Ronkartz72
Louisiana USA
I have the K & N filter on there which has a "Nut" at the bottom to make it easier to loosen, so it may be tighter on mine.
Ronkartz72
Louisiana USA
I added a bit of length on the testers I sent out.
Ronkartz72
Louisiana USA
I am using PLA on a Longer K5 Pro. First printer and first project I built from scratch.
