Paulny
- Nov 5, 2018
Just replaced the stock Duratracs with these Coopers on my Rebel. They are 34.25" tall and ZERO rubbing. The tires get stellar reviews and I picked them over my go to Ridge Grapplers. So far, so good.
Thank you for sharing these photos with us, I was doing some research my self on installing 34’s on my stock Rebel wheels, I think the tires look beautiful on your Chrystal Granite Rebel! Can you share your thoughts with us on ride quality and noise? Grip? Thanks & good luck.
^^^. Perfect as I have plenty of time before I make my choice between the two versions.![]()
Are you running stock suspension or air ride? love the look!
hoping to change my laramie from 20in to the 18in with that tire size.
I love it! I have a 2019 Rebel with air ride as well. Any clearance issue with the upper control arms?Just replaced the stock Duratracs with these Coopers on my Rebel. They are 34.25" tall and ZERO rubbing. The tires get stellar reviews and I picked them over my go to Ridge Grapplers. So far, so good.
Yes it will rubNice set up! Does 295 tires make driving a little sluggish? I have weather tech mud flap with stock suspension, I am not sure if 295 70r18 will rub flap or not, any one out there has mud flaps?
Since I do not off road nor haul, I’m feeling this maybe more in line for my day to day needs.View attachment 12100
I’m also looking to do this. Already ordered the KO 2’s in the 295/70/18. Did they fit with no rub?Thank for posting up. I have a BackCountry with OR and no air suspension no level. I think I would like this size in the Wildpeak A/T3W or KO2's. Without a level kit this shouldn't rub anything?
Where did you find 295/75 r18s in those tires. I would love to do the same but it isn’t showing that they make them.Did the same setup.
2022 ram 1500 rebel with stock tires , stock height and 295/75 r18 cooper tires. Looks beautiful. No rubbing.
