295/70/18 Cooper Discoverer AT3 XLT's on stock Rebel
Paulny
Just replaced the stock Duratracs with these Coopers on my Rebel. They are 34.25" tall and ZERO rubbing. The tires get stellar reviews and I picked them over my go to Ridge Grapplers. So far, so good.
Nice as I’m seriously feeling keeping my Rebel wheels and just going with a slightly bigger tire set up.
I’ve had good luck with Coopers and will likely replace my stock tires with something similar when the time comes
Since I do not off road nor haul, I’m feeling this maybe more in line for my day to day needs.39E2AE83-4ADE-4952-B0E6-BA763ECEDB47.jpeg
Thank you for sharing these photos with us, I was doing some research my self on installing 34’s on my stock Rebel wheels, I think the tires look beautiful on your Chrystal Granite Rebel! Can you share your thoughts with us on ride quality and noise? Grip? Thanks & good luck.
Thanks for the kind words. So far, they are performing as advertised. We have had some hard rain in the past few days, and light snow. These tires are amazingly "sticky" and seemingly have amazing wet weather traction. They are very quiet, which is one reason I purchased them and replaced my stock Duratracs. Overall, I am very pleased with these tires and they look even better in person. I will provide another update in a few weeks after I get a chance to get more miles on them.
^^^. Perfect as I have plenty of time before I make my choice between the two versions. :)
Are you running stock suspension or air ride? love the look!
hoping to change my laramie from 20in to the 18in with that tire size.
I'd honestly just go with the xlts if you are going LT. The tread and on road performance between the 2 is basically the same, the xlts just have a more aggressive sidewall and only come in LT sizes.
I have them in 275/65r20 which is a 34.2 inch tire as well and compared to the stock nexens and the Terra Grappler G2s i had on the truck these are amazing. They're as quiet as the nexens, they're stickier than either of them, and the ride is very cush for an LT tire. The only negative is the weight which is expected with an LT.
I also only lost about 1 mpg city and 1.5 at 75 with 3.92 gears
Yes, stock suspension but I do have air ride. Even at normal low or normal height, zero rubbing. These tires have been amazing in the crappy snow and freezing rain we have had here in upstate NY lately. Thanks for the kind words.
Truck looks great ! I'm looking to run the same size tire on my stock 18" rims. It looks like it would be tight on the UCA's Do you have any rubbing issues.
I have Rough Country leveling struts. Any help would be appreciated.
I love it! I have a 2019 Rebel with air ride as well. Any clearance issue with the upper control arms?
Hmm... This makes me think my falcon medium setting shocks can run a 295/70R18..
If I could swap to larger tires without changing anything, I'd be so happy!
Nice set up! Does 295 tires make driving a little sluggish? I have weather tech mud flap with stock suspension, I am not sure if 295 70r18 will rub flap or not, any one out there has mud flaps?
Yes it will rub
Since I do not off road nor haul, I’m feeling this maybe more in line for my day to day needs.View attachment 12100
I put 100,000 miles each on two sets of these on my 2014 Ram Bighorn. No lift, no off-road, just lots of highway. Bought the first set for the look. Bought the second set because of the mileage I got out of the first set. Much louder than the Goodyear Wranglers that came with the truck but that is what the radio volume knob is for . . .
Thank for posting up. I have a BackCountry with OR and no air suspension no level. I think I would like this size in the Wildpeak A/T3W or KO2's. Without a level kit this shouldn't rub anything?
Did the same setup.
2022 ram 1500 rebel with stock tires , stock height and 295/75 r18 cooper tires. Looks beautiful. No rubbing.
I’m also looking to do this. Already ordered the KO 2’s in the 295/70/18. Did they fit with no rub?
Did the same setup.
Where did you find 295/75 r18s in those tires. I would love to do the same but it isn’t showing that they make them.
