Misaligned bag?
BluDamon
Manchester, NH
My tire shop sent me this photo today after installing a leveling kit and 35" tires on my 1500 Limited. They didn't touch the suspension in the rear but noticed that the passenger side bag is misaligned quite a bit whereas the driver's side is straight up and down. I ordered this truck brand new and it only has 2,500 miles on it.
Can any of you folks with air suspension take a look at yours (from the exhaust looking forward) and see what yours looks like?
Kinda looks like the bag has fallen out of the cap at the top. That might happen if someone jacked it up by the frame without first upping the bag pressure. Or maybe if it was allowed to leak down to nothing sitting in the dealers lot for awhile. I don't have the air suspension, so I'll defer, but think it definitely looks like something that needs fixed.
Might just be a loose dust sleeve
You have air suspension and a leveling kit? Like a spacer kit or just adjustable links? Do you have the off road package ?
I don't think factory air suspension trucks have "ORP". They have different levels of lift they can select, and doing a front level they basically lose one position to gain a higher front lift in noromal ride height mode
Adjustable links in the front only with 2" spacers. It does have the ORP which adds a 1" factory lift even on the air suspension models, and removes the OR2 setting.
What spacer are you running ? I have a longhorn eco diesel with air/off road
