Tuning 2023 models
onrebel
Just starting to look into potential tuning on my 2023 1500 Rebel. I have talked to Diablosport and HP Tuners and both indicated my vehicle is not supported, but would not specify if it was the PCM unlock or the tune itself. However I have talked to some independent tuners that said they could do it as long as my PCM is unlocked. Just curious if anyone has any experience unlocking the PCM on a MY2023 and if there is any difference with the previous model years.
My plan was to purchase a new/additional PCM to get it unlocked and tune on that one, leaving my original PCM stock and untouched. If I could purchase an unlocked PCM from HP Tuners or someone else and then use an independent tuner to do the actual performance tuning, that would be ideal.
Thanks
It’ll probably come around next year or the year after. The same thing happens every year, and they just have to say it’s not supported to cover themselves legally until they’ve done enough testing.
That makes sense, especially for offering a canned tune to the masses. Just hoping to determine if I can get the PCM unlocked and then look at custom tunes.
Thanks
I'm waiting on mine for the '23 as well. Had the diablo tuner I3 on my 2019 back in the day. I think buying a secondary unlocked PCM may be an idea, but who knows what has changed.
I had to wait a while for Diablosport to be able to tune my 2022 I also have an i3.
They claimed the problem was with the unlocking feature. Even after they were able to unlock it they did testing for around 2-3 months before they officially supported it, then i sent out my PCM for an unlocking.
You can call every once in a while and ask their support and they will check with engineering an give you a rough ETA if they are working on it.
There is software that interfaces from the tuner to the PCM, and the tuner generally needs to update to interface with it after they support it even with an unlocked PCM, I would say it's best to wait until HP or Diablo whoever you are going to go with says it's good to go.
It's also EXTREEMELY unlikely they will sell you a PCM due to parts. You would need to buy another one yourself and ship it in. That's what Diablo told me last year when I asked about buying a separate one. They said they could do swaps, but send ins but didn't have any stock or able to order for just outright purchases.
That said why do you want 2 PCMs? you can very back to stock on your tunes if you ever want. I hooked up to my truck even with dealership tools and there are no red flags anywhere about my unit being tuned or unlocked.
Okay thanks for the update. I meant 1 extra unlocked PCM to tune on, but since you said it's okay to use one without any red flags from the dealership I guess its ok.
I mean I haven't had any problems and it's not like you are going to void your warranty unless the tune does damage anyways.
Obviously you break it you buy it.
I'm sure if someone did some digging they could see something might of been done but it wouldn't matter.
The factory tools COUNT FLASHES.. that's how they know if the computer has been tuned. If you turn it back to stock they can still detect the trucks been tuned because they keep all service records digitally and know if and or how mant tiles the dealerships have been in your ecu.
Where's the proof?
Even if what you said is true it means nothing. It's not illegal to flash anything unless you live in Cali where doing anything is illegal. Why does it matter even if it sees how many times it's been flashed? Maybe I had my local repair man flash it since you don't need to go to a dealership for service of any kind unless you want to have it done under warranty and save money.
Where's the proof?
Lol, proof is when the truck is hooked to the scan tool at the dealership, it has a flash counter, literally every manufacturer dies now. If the vehicle has not been in fir ecu updates or has not been updated the flash count will not match records and they can, and almost in every situation will void warranty if major repairs to drive train are needed. Your " local mechanic " does NOT have access to the equipment needed to do ecu updates and refreshes. Your dealer might ne the coolest on the planet but if you go in fir a major repair and the claim is inspected by anyone outside the dealer, what the dealer says doesn't mean squat. Ford red flags vehicles CONSTANTLY and gm and Stallantis are getting real bad.
You have no facts to back this up.
I have flashed my TCM PCM, and even done my own recall for HCP. But sure whatever you say bud.
When you have some facts and maybe pictures to back this up let me know.
The pcm changed. Ram used to use Bosch but for 2023 they went to their own
Thanks
Ironic to see this post! I put up something similar about forced induction solutions - no one supports this 2023 model for some reason. I'd like to know what is so significantly different about this model year.
I know ECM connector location is different than the 2019-2022. Hoping this isn't a standalone model year due to COVID part shortages. Spoke to Pulsar & they don't plan to release a solution model for the 23'. Procharger is "working on R&D".
Subscribing to your thread. Hopefully one of us overturns the right stone.
There aren't any tunes available for the 2023+ Hemi models yet. I just got my truck and am eager to try out one of those plug-and-play tunes once they are available.
Factory computers must be unlocked before any tuning can be done. Once that's done there is no going back they know even if you don't do any flashes.
I tuned my 2020 Ram with HP Tuners myself.
hptuners finally came out with the gpec5 tuning options for the newer ecu's
  • Like
Reactions: SV8
Well, that is music to my ears.
Looking forward to it!
I just sent my GPEC-5 PCM for my 2023 Ram to HP Tuners this past Saturday to get it unlocked. They confirmed receipt on Monday and mentioned it should take 1–3 days to complete the process.
I’ve been looking forward to this for almost two years! So far, I’ve installed an S&B cold air intake, a ported throttle body from Fastman, ARH long tube headers, and a Flowmaster 3-inch laminar flow Pro Muffler. I can’t wait to finally tune it and see everything come together!
Best of luck!
Let us know when you get that.
