Front camera not working - easy fix?
aussie_ram
Las Vegas, NV
Just noticed tonight that the front camera on my 22 Limited isn't working. I don't use surround view much so i guess I didn't notice ... not sure how long it's been out, may have been since I picked it up a few weeks ago.
Does anyone know if there are any things to check that may be a quick fix, so I don't have to deal with all the crap of dropping it off at a dealership for them to look at?
I just had this happen on my 19 Limited also. Did you ever figure out an easy fix solution to resolve this issue or did you have to take it to a dealer?
Mine turned out to be a cable wasn't plugged in properly. Came like that from the factory, turned out to be a simple fix. If you can get access to the front bar to check the connection, I'd do that otherwise the dealer should be able to fix it pretty easily.
