Ticking of doom?
killerformula
Hi all,
Have the ram in my sig. about 22k miles.
I haven’t been driving it as much lately and it has been idle in the garage for maybe 2 weeks. I fired it up the other day to drive it, and noticed a rally distinct ticking coming dr the motor. Maybe drivers side. Lasted a good bit of time maybe 20 seconds.
Next time I fired it up the next day I didn’t hear anything. Makes me think it is not a manifold issue.
Is this normal after sitting for 2 weeks? Wonder if we have an emerging lifter issue here?
What should be my next steps?
Thanks all!
silver billet
That's "normal", it affects a ton of hemis. You can try running a different oil filter, one with a silicone anti drain back valve. Fram Ultra or Royal Purple are great filters.
This tick is not one to worry about. The tick that is worrisome is the one that stays around with a hot idle. If it goes away pretty fast when it's cold, it's either lifter bleed down (like it sounds like in your case) or broken manifold/manifold bolts.
arod412
NJ
My current ram...the start up ticking it's alot louder Than my previous hemi's (2020 Laramie, 2021 rebel with etorque).
But I just cough it up as normal.
2016 Dodge Charger scat pack
frisby5
My truck sits around alot ,sometimes a couple of weeks and it does that when starting up.
