This is the one you want. It gets plugged in behind your bumper.
CURT 55384 Replacement Vehicle-Side Custom USCAR 4-Pin Trailer Wiring Harness, Black, 6 x 3 x 9 inches
https://a.co/d/3GO6SKH
Thank you. Someone mentioned there is a constant 12 volts on tow wiring.
I’ve maybe plugged in a trailer twice in my life. So not super familiar. Actually do not ever plan to tow anything with this truck
But this harness appears to have two multi pin round connectors and the multi pin flat connector.
Trying to envision what connects where with this.
When you say this is what I need to order is that to connect any type of lights that I could find or are you thinking the OEM light?
I ordered it.
I found this set of lights that are supposed to be brighter than OEM that might be good.
Not sure yet if they turn on and off by pressing on one of them. I think oem ones do.
I’m not sure how elaborate I wanna get with running the lights because my bed has the bed rug in it
I’m thinking using the oem light cut out would probably be the most simple.
Thanks
