It will be a help to point in the right direction to find the correct part for other coloursThe led light and wiring part numbers should be good to go for all DT's , the only part number is going to change is the handle... because of color and if it has the chrome insert.... Mine is BlueSteel w/o chrome, I can post that number if it helps any member...
-=FM45=-
Besides the led light, wiring harness, and handle do you need any other OE parts to make this work? Looking forward to your write up! Thanks.The led light and wiring part numbers should be good to go for all DT's , the only part number is going to change is the handle... because of color and if it has the chrome insert.... Mine is BlueSteel w/o chrome, I can post that number if it helps any member...
-=FM45=-
This is my part number that I ordered for my vehicle. Maxsteel without chrome insert.If you can verify that the paint code on your truck is KAR then that part of the p/N is the colour code for the part. That's how it worked when I bought the door handles for my truck. Paint code is PAU P/N is 6CV64LAUAD. LAU appears to be an alternative to the same code.--- Just the 3 parts to make everything work, no other OE parts required... you will need 2 diodes and approx 2 ft of 22 gauge wire. All will be in my write-up..
View attachment 159542 This is my part number that I ordered for my vehicle. Bluesteel without chrome insert.
For other colors start here--
Tailgate.. 2022 Ram 1500 5.7L HEMI V8 4WD Limited Crew Cab - Myrtle Beach SC
2022 Ram 1500 5.7L HEMI V8 4WD Limited Crew Cab Tailgate.www.moparpartsinc.com
Look at Part #4, then My part number ... 7KJ40KARAA --- read the description to understand the listing
I believe depending on your Ram, the first 4 digits remain constant and the renaming will change with the color --- I am no expert so YOU must do your homework before you order... For EX... read Mopar's description of my handle, says Red -- and no mention of BlueSteel...
If anybody knows how to speak Mopar please stand-up....
-=FM45=-
-=FM45=-
In part numbers that are color specific, the 7th and 8th value in the part number will always represent the last two values of the paint code.If you can verify that the paint code on your truck is KAR then that part of the p/N is the colour code for the part. That's how it worked when I bought the door handles for my truck. Paint code is PAU P/N is 6CV64LAUAD. LAU appears to be an alternative to the same code.
Looks good, but I think there is multiple wiring options for the tailgate depending on if you have the surroundview or parkview camera. And standard or multifunction tailgate.Here is the write-up... just thrown together. Hopefully I didn't miss anything or make many mistakes, I was going off memory..
-=FM45=-
Thanks for writing this up. Now I wonder if it’s a similar process for a truck with surround view and MFTG. @Jimmy07 would following FM45s write work the same with surround view and MFTG?Here is the write-up... just thrown together. Hopefully I didn't miss anything or make many mistakes, I was going off memory..
**** Make Note--- This is for the STANDARD tailgate w/o surround view ****
-=FM45=-
I wonder if one harness is for the MFTG and the other is for one without? Were you able to find anything out on the differences?I have a 2021 1500 Rebel that I would love to get this done to. I have factory surround view and not sure which wiring harness I have to get to get this mod done. These are the two options that I see online and not sure what the difference is. I DO NOT have a MFTG:
68531010AB
68531011AB
As far as the handle itself, I’m having a hard time figuring out the whole color code or which handle to purchase. My Rebel is diamond black crystal pearl and with having surround view I’m not entirely sure which one to get if any one can guide me and post the exact part number I need to order.
Thanks in advance!
I am not a professional but, according to MOPAR Parts and Accessories - Save up to 40% the part numbers you providedI have a 2021 1500 Rebel that I would love to get this done to. I have factory surround view and not sure which wiring harness I have to get to get this mod done. These are the two options that I see online and not sure what the difference is. I DO NOT have a MFTG:
68531010AB
68531011AB
Thanks in advance!
68531010AB [Locking Tailgate], [ParkView Rear Back-up Camera].
68531011AB [Locking Tailgate], [Surround View Camera System].
Again not a professional but that is what the website says
That's the first time I've used that site. It was linked in an earlier post in this thread. In that post the author claims the part was labeled wrong so just be carefulPerfect. Other websites that I’ve seen don’t even mention that part so I appreciate it. I’ll be using that site from now on.
