Standard Coil vs. Air Suspension - my back to back review FWIW
dn325ci
I'm in a process of working out the spec for my truck order and I wanted to know about how the coil and air systems compared. Local dealerships were generous to allow me extended drive times on my own and I spent hours on the local roads I know well, ranging from interstate to city streets to country two-lane roads. I thought there may be others interested in this topic, so I felt it might be good to summarize here.
My context:
1. Not a money thing for me - I'm fine paying for the option if there is a benefit.
2. I won't be towing hardly at all.
3. I won't be hauling heavy loads very often.
4. I'm primarily interested if there is a ride quality benefit either way. My definition of a better ride is less impact harshness on significant road imperfections - potholes or train tracks or patched roads or asphalt issues we typically see here in Ohio.
Now I've had a number of german cars with air suspension and usually the german manufacturers will go to air suspensions on their higher end models and trims for a ride quality benefit, though not typically for sportier handling. So I fully expected the Ram with 4 corner air suspension to be the better riding vehicle. But because I'm interested in this subject, I had researched all the major reviews and manufacturer's marketing materials about it, and I was noticing an obvious lack of discussion of air suspension ride improvement over the coil suspension. No one really compares them, so I felt compelled to test it myself.
I drove a brand new Laramie with standard coil suspension that very few miles first. The Laramie had 20" wheels. I compared that to a Laramie Longhorn that had about 3,000 miles because it was the GM's personal demo car. Both were crew cab 4x4's with the 5'7" box. The Longhorn had the optional 22" wheels.
The results were a surprise to me, so I felt I should mention it. The coil suspended vehicle definitely felt like it had the slightly more compliant ride. Because of my experience in luxury sedans, I didn't expect this, and it made me start to question whether the 22" wheels were a factor, and maybe they are. Handling in the corners felt the same between the two vehicles. The conclusion I arrived at from the back to back comparison was that the air suspension was noticeably less compliant than the coil suspension, and even if it were mostly due to the 22" wheels, it was hard for me to imagine that the 20" wheels would make it an improvement over the coil suspension, so for my use case I won't be checking that option box. Hopefully this info is of value to the forum.
Thanks,
Don
My context:
Thanks,
Don
Did either of the vehicles have 4wd or Off-road package? Just curious.
Both trucks were 4x4 crew cabs and neither had off-road package.
Don
I drove them back to back and tend to agree. I ended up buying an air suspension model though because I do tow a camper, and the truck I found that had the config I wanted had it. It certainly was not a must have though.
I drove both back-to-back on multiple occasions (and also compared them with the GM Magnetic Ride Control back-to-back). In my opinion, both ride very well. The Ram coil suspension is noticeably more controlled than, say, an F-150 suspension. And I would agree with your assessment that it's (just a bit) softer (more compliant) than the air suspension on "normal" pavement. The Ram air suspension gives the truck a "heavier" feel, but not in a bad way; the truck just feels a bit more planted. Where the air suspension really shines (aside from towing) is over large bumps, e.g. railroad crossings, dips, etc. It handles these beautifully...like they're invisible. Obviously (per my signature), I opted for the air ride.
I appreciate the write up. Everyone is going to have a different feel for each of the suspension options and should go with what they believe is best for their needs. For me, because I have a 6000lb trailer and for the overall ride for me, air suspension was the best choice. For others, I can certainly see why some would elect to not have it, whether it be a gimmick as some say or not. In any case, best luck with your choice @dn325ci. Post pics when you have your Ram.
I tried with and without, and went with the air suspension. I'd compare the 2 with similar wheel and tire options if you really want to be sure.
...and I bought the Limited after selling my Mercedes GL 450 with air suspension. It's still a truck, but it drives really nicely.
My context:
Thanks,
Don
Thanks for your comparison. I have no experience with air suspension. While shopping for the Ram one salesman said the ride was not better with the air suspension, so I never considered it as an option. Later on I had my doubts but you reaffirm the salesman opinion.
I've done the back-to-back test with both `18s and `19s. On the `18s my first ride with an air suspension was like an orgasmic magic carpet ride. With the `19s it was like, gee, it doesn't feel any better and if anything its a bit more harsh than the coil. The sales guy, who was a factory trained Ram specialist, said "I've never heard FCA state that the 4-corner suspension improved ride".
So I removed the 4-corner thing from my truck buying rubric, but from the experience in the `18 I was subconsciously hooked as if I still craved the blissful cocoon of my mother's womb. So then 2-days ago my primal urges took control of me, and against my better judgement I bought a `19 with 4-corner. On the ride home after a few jolts on the freeway I was cursing my decision.
When I got home, and still pissed at myself the whole family piled into the car demanding a ride and I drove them around over some bumpy streets and the thing settled down marvelously. Driving it to work today wasn't so bad either. I'm thinking with a camper shell and few bags of sand in the back I will have that boat cruising along like the land yacht it was meant to be.
4-corner really is a handy feature. Note to Ram: provide some ride controls on the thing, like you know "firm", "regular", and "marshmallow soft cushy". And fine, auto-disable the cushy toosh mode over 60 just to be safe, but mark my words, that last setting if you implement it will sell a million of these things.
Make sure you're in the correct ride height before passing judgment. Some of us have found that remote start seems to prevent the truck from automatically adjusting ride height. It's what we IT guys call an "undocumented feature".
I would say the majority of the difference felt was the 1" less sidewall that the air suspension truck had. However, i would also not doubt that air suspension may be slightly less smooth than the standard coils when truck is empty. Towing, however, should give the advantage back to the air suspension.
Also, if it was equipped with the offroad package and air, you'd be riding around in a slightly stiffer setting than a non offroad package truck
I can't imagine a much smoother ride for a truck than my current 4th with 20s and standard coils, though.
My last Ram (14' model) did not have the air-ride suspension and rode like a dream. Then switched to the 16' F150 4x4 platinum and it rode more like a truck. I do occasionally pull a trailer and if you ever put more than 2-300 lbs in the back you will wish you had the air-ride suspension. I just picked up my new 19' Ram Limited and would never own another Ram without the air-ride. My truck came with the 22" wheels and the truck rides very smooth, definitely feels more solid over bumpy roads (less springy). In my opinion, you may be satisfied without the air-ride but you'll never regret it if you get the air-ride, especially if you ever haul or pull a trailer.
Maybe it's me, but I traded my 19 4x4 Sport for a limited 2wd and the difference is night and day. of course it 'could' be the 4wd components underneath, IDK. But my limited rides like a Cadillac...no lie. It's much smoother than the coils, IMO.
Hi MHB, almost same EXACT scenerio here, its not just you... : )...i also had 4 corner air in my 2018 Ram SPORT 4x4, i had it leveled with 35 inch G2's on 20 inch wheels.. Ride was good, for sure, and maybe its many of the differences cited here (not towing/ different settings (aero mode disabled ALWAYS) but i am 100% with you MHB. i test drove a 2WD 2019 with no level, stock wheels and tires and THE RIDE and FEEL blew me away. I traded mine in the NEXT day and have never looked back : )
This will be the very FIRST Ram i do not "touch", and our FIRST 2wd...my hubby has a 2016 lifted 2500 Laramie but bought a 2019 2WD RAM for a daily driver also and has ALREADY (next day : ) put level and 34's. His actually looks more like a 4x4 with "slight 1 inch rake vs mine with COMPLETE 3 inch rake, but that still will never convince me to change ANYTHING stock in mine ONE IOTA....I'll just drive either one of HIS if i need to get that, "high & mighty" feeling : ) Besides, since its a 2wd, i actually think the rake adds to the look a little bit, and i have never thought THAT before! And the ride and handling blows me away every day!
Here's a pic of both my 2018 & 2019 (and i'll throw in his 2016 for good measure : ) (and no i don't know why my pics upload in triplicates, i try to delete then they don't show at all
(sorry : )resized.pngblack.jpgbrown.JPGresized.pngblack.jpgbrown.JPG
My previous truck was a 17 Rebel which had air suspension standard and I currently have a new Rebel without air suspension. Both trucks are/were stock. 2019 ride is significantly smoother which took my by surprise. Initially I wanted air suspension option but after driving coil springs i forgot all about air. Rebels have similar wheels and rubber to include different schocks so that may play a role in smooth ride vs big horn/limited trims.
