beaud666
Hello,
I'm shopping for new wheels and hesitating what offset i should get. I have a 2019 laramie 1500.
Anyone here, run 20x10 et0 and et-12?
I would like to see some pictures. Also considering -18.. i will wrap them with either 295/60r20 or 285/65r20 falken wildpeak at3w. I want a semi agressive look.
Lets see what you have. Thanks
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
20x10 -12 offset is pretty uncommon, typically you’ll see -24 or -18 offset. 20x10 0 offset is even less common than that lol. Usually 0 offset will be a 9” wide wheel
beaud666
I got a couple in my cart. Fast Hd make some nice one et0 and level8 et-12 they are 20x10
Idahoktm
North Idaho
Whats your level? Does the tires rub? Any trimming or anything to do?
Thanks for sharing.
2" Readylift. They rubbed my mud guards at full lock backing up. I trimmed off some plastic and they don't rub any more.
Happyswiss
SoFlo
Just wondering if you ever got anywhere with the 20x10 et0. I joined the forum to help my quest searching for these oddballs and get rid of my 22s. Your post is the only one to touch this topic, but neither Fast HD or Level8 offer the et0.
So far it looks like I have to ask Vossen if they can do something like a custom HF6-3 20x10 et0.
I want a flush look with wider tires and keep the stress off the bearings. 5.5” backspacing on a 10-wide et0 gives you that and .35” more room inside to prevent rubs, the 1.15” more wheel towards the outside will fill the fender wells with no rub when using 305/50-20 shoes. Pure math.
If you have any pics of your solution at this point, mind sharing them?🙏
