first ram truck
2022. laramie sport.
yeah i've already spent a bit. just ordered the auto side steps.
Welcome to the forum lots of good people and information out there! Congrats on the new truck and being part of the Ram fam!
Looks great, congrats!
so here is a list of the options.
Equipment Listing
Vehicle Description 2022 RAM 1500 SPORT CREW CAB 4X4
MONOTONE PAINT
730 AMP MAINTENANCE FREE BATTERY BRAKE ASSIST
RAIN BRAKE SUPPORT
READY ALERT BRAKING ELECTRONIC STABILITY CONTROL HILL START ASSIST
TRACTION CONTROL ELECTRONIC ROLL MITIGATION TRAILER SWAY DAMPING
ANTI-LOCK 4-WHEEL DISC BRAKES 2ND ROW IN FLOOR STORAGE BINS KEY FOB - SATIN CHROME
FRONT HEIGHT ADJUST SHOULDER BELTS SUPPLEMENTAL SIDE AIR BAGS
CHILD SEAT ANCHOR SYSTEM-LATCH READY ADVANCED MULTISTAGE FRONT AIR BAGS SUPPLEMENTAL FRT SEAT SIDE AIR BAGS CARPET FLOOR COVERING
CARGO TIE DOWN LOOPS FRONT & REAR FLOOR MATS
DOOR SILL SCUFF PADS DRIVER/PASSENGER ASSIST HANDLES
STANDARD EQUIPMENT
DELUXE DOOR TRIM PANEL
FULL LENGTH UPGRADED FLOOR CONSOLE PREMIUM OVERHEAD CONSOLE
FOAM BOTTLE INSERT (DOOR TRIM PNL) ROTARY SHIFTER-BRIGHT
ELECTRONIC RANGE SELECT
ELEC SHIFT ON DEMAND TRANSFER CASE 215MM FRONT AXLE
3.21 REAR AXLE RATIO
235MM REAR AXLE
CONVENTIONAL DIFFERENTIAL REAR AXLE TINTED GLASS WINDOWS
ACOUSTIC FRONT DOOR GLASS
DEEP TINT SUNSCREEN GLASS
REAR WINDOW DEFROSTER
REAR POWER SLIDING WINDOW
SUN VISORS W/ILLUM VANITY MIRRORS BODY COLOR PREMIUM POWER MIRRORS REMOTE KEYLESS ENTRY
SENTRY KEY THEFT DETERRENT SYSTEM PUSHBUTTON START
DASH LINER INSULATION
CLUSTER 7.0" TFT COLOR DISPLAY
200 KPH PRIMARY SPEEDOMETER
VAR INTERMITTENT WINDSHIELD WIPERS DUAL NOTE ELECTRIC HORNS
12V AUXILIARY POWER OUTLET
LOCKING GLOVE BOX
115V AUXILIARY POWER OUTLET
POWER ACCESSORY DELAY N95+BIO HVAC CABIN FILTER SPEED SENSITIVE POWER LOCKS
PWR FRONT WINDOWS, 1-TOUCH,UP & DOWN INSTRUMENT CLUSTER THEME 1 (BASE)
ILLUMINATED ENTRY TIRE FILL ALERT
FRONT PASSENGER SEAT BELT ALERT LED TAILLAMPS
VEHICLE INFORMATION CENTER FOOTWELL COURTESY LAMP GLOVE BOX LAMP
OVERHEAD CUPHOLDER LAMP HEADLAMP OFF TIME DELAY OVERHEAD LED LAMPS AUTOMATIC HEADLAMPS
AUTO HIGH BEAM HEADLAMP CONTROL DAYTIME RUNNING HEADLAMPS, LOW BEAM FRONT LED FOG LAMPS
REAR LICENSE PLATE W/LAMP BRACKET LED REFLECTOR HEADLAMPS
FULL SPEED FWD COLLISION WARN PLUS BODY COLOR FRONT BUMPER
BODY COLOR REAR BUMPER W/STEP PADS FRONT LICENSE PLATE BRACKET
ACTIVE GRILLE SHUTTERS FRONT WHEEL SPATS "RAM" DOOR BADGES BLACK HEADLAMP BEZELS
RAM'S HEAD BADGE FRONT WHEEL WELL LINERS
BLACK DAY LIGHT OPENING MOLDINGS BODY COLOR DOOR HANDLES
REAR WHEEL SPATS "1500" BADGE SPORT BADGE
4X4 BADGE DAMPENED TAILGATE
FIXED FRONT AIR DAMS ACTIVE FRONT AIR DAMS
"RAM" GRILLE BADGE - CHROME BLACK EXTERIOR BADGING - TRUCKS
26 GALLON FUEL TANK ENGINE BLOCK HEATER SPEED CONTROL FLAME RED CLEAR COAT
STEERING WHEEL MOUNTED AUDIO CTRLS ACCENT COLOR SHARK FIN ANTENNA MEDIA HUB-2 USB, FULL FUNCT, AUX AUDIO JACK INPUT FOR MOBILE DEVICES REMOTE USB PORT
REMOTE USB PORT - CHARGE ONLY ELECTRIC POWER STEERING
PERFORATED STRNG WHL W/ACCENT STITCH FRONT HEAVY DUTY SHOCK ABSORBERS REAR HEAVY DUTY SHOCK ABSORBERS FRONT STABILIZER BAR
REAR STABILIZER BAR
TILT/TELESCOPE STEERING COLUMN TIRE CARRIER WINCH
FULL SIZE TEMPORARY USE SPARE TIRE CENTER HUB
18" FULL SIZE STEEL SPARE WHEEL PARKVIEW REAR BACK-UP CAMERA POWER ADJUSTABLE PEDALS
TIP START PICKUP BOX
OCCUPANT CLASSIFICATION SYSTEM COAT HOOKS
ELECTRIC PARK BRAKE CLASS III BUMPER HITCH 7 PIN WIRING HARNESS
FRONT/REAR CLIMATE CONTROL OUTLETS UNIVERSAL GARAGE DOOR OPENER TIRE PRESSURE MONITORING DISPLAY
REAR SEAT HEAT DUCTS 400W INVERTER LOCKING TAILGATE CAPLESS FUEL FILL ELECTRONIC SHIFT REAR BUMPER MODULE FRONT BUMPER MODULE GRILLE MODULE
HEADLAMP PARTS MODULE DOOR TRIM PANEL MODULE GLASS MODULE
STEERING COLUMN COVER PARTS MODULE
CENTER CONSOLE PARTS MODULE FRONT FASCIAS PARTS MODULE HEADLINER PARTS MODULE
SEAT PARTS MODULE INSTRUMENT PANEL PARTS MODULE DOOR PARTS MODULE
FRONT END PARTS MODULE TIRE & WHEEL PARTS MODULE
FRONT SUSPENSION DAMPER PARTS MODULE REAR SUSPENSION DAMPER PARTS MODULE BUILD TO CANADA MKT. SPECIFICATIONS CANADA DEALER RETAIL
ZONE 21-CANADA-ONTARIO CREW CAB
FOUR WHEEL DRIVE (4WD)/(4X4) PRICE CLASS T
2022 VEHICLE SPECIFICATIONS 5 FT. CARGO BOX
VEHICLE ORDER TRACKING CANADA SPECIFICATIONS LABEL ONTARIO PROVINCE CODE CANADA COUNTRY CODE
LEATHER TRIMMED BUCKET SEATS
BLACK
TECHNOLOGY GROUP
COMFORT/CONVENIENCE GROUP
NIGHT EDITION
OPTIONAL EQUIPMENT
REBEL LEVEL 2 EQUIPMENT GROUP 220 AMP ALTERNATOR
ADVANCED BRAKE ASSIST BUCKET SEATS VENTILATED FRONT SEATS 4 WAY FRONT HEADRESTS REAR 60/40 FOLDING SEAT
SUPP. SIDE CURTAIN FRT/RR AIR BAGS HEATED FRONT SEATS
THREE REAR SEAT HEAD RESTRAINTS FRONT SEAT BACK MAP POCKETS
DELETE UNDERSEAT STORAGE COMPARTMENT 8-SPD AUTO 8HP75 TRANS
5.7L V8 HEMI MDS VVT ENGINE AUTO DIM EXTERIOR DRIVER MIRROR DIGITAL REARVIEW MIRROR
DUAL-PANE PANORAMIC SUNROOF 2-DOOR PASSIVE ENTRY, FRT DOOR LOCKS AIR COND ATC W/DUAL ZONE CONTROL RAIN SENSITIVE WINDSHIELD WIPERS 115V AUXILIARY REAR POWER OUTLET REMOTE TAILGATE RELEASE
GPS NAVIGATION GPS ANTENNA INPUT
ACTIVE NOISE CONTROL SYSTEM POWER 2-WAY DRIVER LUMBAR ADJUST HEATED SECOND ROW SEATS
POWER 2-WAY PASSENGER LUMBAR ADJUST POWER 8-WAY DRIVER/PASSENGER SEATS
HEAD UP DISPLAY
DOME DUAL LED READING LAMP
EXT. MIRRORS W/SUPPLEMENTAL SIGNALS EXTERIOR MIRRORS COURTESY LAMPS EXTERIOR MIRRORS W/MEMORY
BODY COLOR EXTERIOR MIRRORS DRIVER SEAT MEMORY
POWER-FOLDING MIRRORS
CONVEX WIDE-ANGLE EXT MIRROR INSERT DELETE LED LAMP - FLOOR CONSOLE BIN LED CHMSL LAMP
SECURITY ALARM
GRILLE-SURR 3 BLACK TEXTURE 2 BLACK SPORT PERFORMANCE HOOD
REAR WHEELHOUSE LINERS
HEMI BADGE
50 STATE EMISSIONS
PASSIVE TUNED MASS DAMPER
DUAL EXHAUST WITH BLACK TIPS EXTERIOR MIRRORS W/HEATING ELEMENT HEATED STEERING WHEEL
HEAVY DUTY ENGINE COOLING
ALL RADIO EQUIPPED VEHICLES
9 AMPLIFIED SPEAKERS W/SUBWOOFER GLOBAL TELEMATICS BOX MODULE (TBM) HD RADIO
12.0" TOUCHSCREEN DISPLAY
APPLE CARPLAY
DISASSOCIATED TOUCHSCREEN DISPLAY WIRELESS CHARGING PAD
GOOGLE ANDROID AUTO
USB HOST FLIP
MEDIA HUB-2 USBS (BOTH CHARGE-ONLY) INTEGRATED CENTER STACK RADIO CONNECTIVITY - US/CANADA
4G LTE WI-FI HOT SPOT
SIRIUSXM WITH 360L
CONNECTED TRAVEL & TRAFFIC SERVICES ALL R1 HIGH RADIOS
285/45R22XL BSW ALL SEASON TIRES PIRELLI BRAND TIRES
UCONNECT 5 NAV W 12.0" DISPLAY (CAN) ALL ALUMINUM WHEELS
22X9.0 FORGED ALUM WHEEL
REMOTE START SYSTEM
PARKSENSE FR/RR PARK ASSIST W/STOP ENGLISH/USA LANGUAGE
INTEGRATED VOICE COMMAND W/BLUETOOTH FOR MORE INFO, CALL 888-539-7474 SIRIUSXM RADIO SERVICE
FOR DETAILS, VISIT DRIVEUCONNECT.COM 4.5 ADDITIONAL GALLONS OF GAS
SPRING - LEFT FRONT SPRING - LEFT REAR SPRING - RIGHT FRONT SPRING - RIGHT REAR GVW RATING - 7100#
Welcome! For "slim pickings" looks like you got a pretty nice rig!
Congratulations on your new vehicle and welcome to the forum! If you ever have any questions or need any assistance, please reach out to us! We're available via direct messaging!
Callie
Ram Cares
so far its ok, had a 2018 sierra denali 6.2. the ram is more spacious inside but the console seems awkward to get into, the part that slides back wish it moved forward more.
the 12 inch display is nice. still playing with it. guess we can not add apps. im android so i can see most apps on my phone. but some dont show. wish i could adjust the screen i bit more, like add more links to the status bar. or add more links on the bottom.
also randomly asks to finish setting up a profile. today i saw an option to not ask anymore.
wish there was a clear way to know my profile was saved to my fob. most of this is most likely me and not knowing the system.
but over all i'm happy.
god i gotta stop with the extras. lol
oem automatic running boards, fender flares, oem under seat organizer, bed rug, tonneau cover, oem bumper step, s&b CAI, plus a bunch of interior crap off amazon.
but down the road think i want the front and mirror cameras, i have the backup and 3rd brake cameras.
not sure if i'll get a tuner for the ram yet. but wont decide on that until i have aleast 5000 km on her.
