Corrosion on hood
moabbikr
I have a 2019 Rebel and my hood is starting to show signs of corrosion in three spots, is this covered under warranty? Not sure what's considered an outer panel.
Scram1500
That's probably not corrosion but extra panel/body glue
Cbty2050
The hardest part is finding a dealer that will warranty it. Never hurts to contact your dealer and have them start the digital imaging process.
79 300
It has to be perforation through a panel to count any corrosion for warranty, at least that is what I was told years ago.
BowDown
Frisco TX
Looks like a paint run to me
MannyN
Can't be, the hood is aluminum. Maybe a rock chip.
Scram1500
Poke at it with your finger nail, if it's a blister you'll know right away
Scram1500
The back door of early Ford Expeditions and Volvo wagons from the 90's springs to mind
SD Rebel
San Diego, CA
The hood is aluminum, and if not prepped properly prior to painting, the paint can bubble.
If you stick your fingernail on that bump, it should feel fragile, easy to push in if that is the case.
