Found metal shaving in front differential
hortoni
Hi Everyone,
I have a 2019 Ram Rebel 5.7 Hemi with 64,000 miles. I'm changing the front and rear differential oil as well as the transfer case fluid. I'm not in 4wd very often but 23000 of the 64k miles have been towing a 8500 lb camper so I try to stay on top of these.
When draining the front differential, I saw a piece of metal shaving and was able to pull it out with needle nose pliers. The plug itself was clean and the oil also looked fine. I've noticed no noise or any problems from the 4wd system. Should I be concerned? Is there a chance this was just from the initial manufacturing process?
Thanks!
hortoni
I'll add that the shaving looks like aluminum. It is not magnetic.
HemiDude
Ohio
That is a pretty big shaving. The fact that you haven't experienced any issues leads me to think that you likely won't, but I would keep an eye on it
6of36
Michigan
I'm between Rams right now, so I can't even look at construction, but do they have aluminum covers by chance? If so, to me it looks like maybe a chip from tapping the hole in the cover for the plug? I have seen chips hang on pipe fittings, and maybe the same happened and they missed it. There wouldn't be any aluminum inside a differential.
hortoni
I had the same thought. Without any other signs of metal or oil contamination I think I'll probably just keep an eye on it. I have the extended warranty until 120K miles but I have a $200 deductable so unless it looks like a problem, I don't see the need to pay the dealership to remove the case cover and inspect.
