ReadyLIFT 6" lift installed - 2019 Blue Streak
RHINO60
Been driving my truck for almost 4 years completely bone stock but have always had plans for a lift/wheel/tires some day. After quite a bit of research I decided to go with the ReadyLIFT 6" with 37's and couldn't be happier!
Also swapped all the chrome emblems to the factory Mopar matte black emblems to better match the new wheel color.
Install was definitely a big job for only jack stands in the driveway but not too challenging. Just time consuming looking for bolts/tools/parts. After getting an alignment and adjusting the speedo (alphaOBD), the truck drives great!
The 3.92 rear-end helps to keep the loss in acceleration performance to a minimum and I still get 21-23mpg with cruise control set around 52-55 MPH on the way to work so not too bad!
Will most likely be swapping to black exhaust tips or cat-back w/ black tips in the near future.
LIFT: ReadyLIFT 6"
WHEELS: Vossen HF6-5 - 22"x10" (offset: -18)
TIRES: Toyo Open Country A/T III 37x12.5R22
Looks great! The blue and black combination really pops. Can't say that I recall seeing many guys on 37's and 22" wheels, but it is a clean look. Well done job all around!
Thanks!! I looked into 35's but I think lifted RAM's handle the bigger tire sizes really well compared to other half-tons. The wheel wells have a nice arch to help keep rubbing to a minimum. Only required minor plastic trimming.
I did have slight hesitation on 22" vs 20" but the 37's have plenty of sidewall so they don't look too low profile.
Thanks again.
Looks fantastic! Congrats
LIFT: ReadyLIFT 6"
View attachment 155165View attachment 155182View attachment 155183View attachment 155188
Looks great!! What is the overall height of your new setup? I’m wondering if I do this, if it’ll still fit in my garage…
