MaxTrac Rear Leveling/Lowering Springs
Bionicbo
Just ordered my MaxTrac 2" rear lowering springs, should have them here and installed this weekend.
My question to anyone that knows, is it a true 2" drop. I double checked measurements and it's 38 1/8 in the rear and 36 3/8 in the front, based on that I'd actually have some squat.
Mine was a little less than 2 I think.
That's good to know, I see you have the etorque as do I and read that, it could bring it down up to an inch more
Mine looked almost perfectly level. I never measured though.
Measured, mine was a little less, but it looks level and that's all that matters.
Mine with the 2” springs was still a little higher in the rear so I cut almost a full coil off of them and it sat level. Ride quality was exactly the same as stock.
I originally purchased the drop coils. The driver side was 3/4" lower than the passenger side. I had to remove the passenger side 3 times until I got it perfect. This was all good until I pulled a boat or loaded the bed for vacation. Recently removed the coils and replaced them with Firestone Ride-rite air bags. Now I can cater to whatever load I have. Rides better than the coils and I can make them perfectly level with the front or if I want some rake just add a little air. I don't have the onboard compressor yet but plan on adding one soon and it will be dual path as the passenger side takes 5lbs less than the driver side to sit perfect.
That’s funny. Mine sits low too. But I just cut springs 😂
