I'm using these on my truck. Seem to work good. Havnt had any issues. But I don't use them a lot either because my windshield is ceramic coatedFolks, it's time.
What brand and what size wiper blade have you used (that works!) on our trucks?
Thanks.
Same here. These have worked best for me and have lasted (non-streaking) longest. Helps to have RainX as your windshield washer fluid as well - once I'm above 55mph I don't even need my wipers in regular (non-downpour) rain.I run the Bosh ICON 22A (driver's side) and 22B (passenger side). I've had great luck with these in the Michigan climate and I get good performance out of them for three years.
SameI run the Bosh ICON 22A (driver's side) and 22B (passenger side). I've had great luck with these in the Michigan climate and I get good performance out of them for three years.
same except mine take a beating in New York and still out perform any others I have tried.I run the Bosh ICON 22A (driver's side) and 22B (passenger side). I've had great luck with these in the Michigan climate and I get good performance out of them for three years.
I use Icons too.Same here. These have worked best for me and have lasted (non-streaking) longest. Helps to have RainX as your windshield washer fluid as well - once I'm above 55mph I don't even need my wipers in regular (non-downpour) rain.
They make a version you apply on your windshield and rub it in also.I use Icons too.
Rain-X washer fluid up here in Canada is now garbage - not water repellent at all anymore. I used it for years summer and winter variants without issue, but the last two jugs I bought at different stores have sucked. I checked the label on the jugs to make sure it still says it's water repellent and it does, so I sent a complaint to Rain-X to see what they say. I have the last jug here with the lot code in the event there was a manufacturing issue.
I'm aware but it's pricey up here and the washer fluid is convenient. Well it was...now it doesn't work.They make a version you apply on your windshield and rub it in also.
I use Meguiar's ceramic spray wax but the wipers rub it off too quick.You can also use NU finish or any ceramic spray also.
I haven't had a response from them - maybe they stopped using the additive and are lying about it so it was pulled?I can no longer buy Rainx windshield washer fluid, no one stocks it here anymore, Autozone, Walmart, etc
Same.22-inch both sides. Michelin branded wipers (I don't know who makes them) from Costco.
STeve
