ErnestRocks19
 - Nov 20, 2018
What kits are you all putting on or has any dealer released a new kit? Everything says does not fit diesel.
			Which lift did you like best? I saw Bilstein has 5100 available now for our trucks. Wondering if the 2.5” .I’ve had 3 different “lifts” on my ORG already. Readylift 2” leveling/ rear spacer, Fox 2.0 fronts/ rear spacer, and fox 2.5 fronts/ rear spacer. The incompatibility comes in at a 4” lift. The front driveshaft will be short after installing any 4”+ lift. I think the answer will be a double u-joint on the driveshaft, but I’m not going to go that route since I’ll most likely be trading in next year.
Fox by far. The ride is excellent on the street. I haven’t done any real off roading, so I can’t speak to that. There is one lift kit that I left off of here because I bought it for my hemi 5th gen, which is the eibach kit. That one was pretty good also, but the springs were pretty firm and I would’ve preferred less compression on the front shocks. I don’t have any experience with the bilsteins since they were on back order every time I tried to get them.Which lift did you like best? I saw Bilstein has 5100 available now for our trucks. Wondering if the 2.5” .
Dying to lift my ecodiesel, but so far only thing I see is Carli suspension at like $6k plus another $3-4k for rims/tires… not sure I want to do it that bad.No all the dealers say it wont work
Im contemplating going back to the 5.7 just for the lift but it tears me up going back to 12-4 mpg lolI just want 4” of lift that’s function over form, but it’s pretty depressing that there’s no options for the ecodiesel.
