dodgedifferent2
- Dec 28, 2022
I’m going to go out on a limb and guess that @dodgedifferent2 isn't short a tape measure; he’s short a TRX.Milwaukee 25 ft. x 1-1/16 in. Compact Magnetic Tape Measure with 15 ft. Reach 48-22-0325 - The Home Depot
The Milwaukee 25 ft. Compact Magnetic Tape Measures have up to 15 ft. of reach and a magnet that easily attaches to EMT & steel studs. The tape is wear and impact-resistant with nylon blade protectionwww.homedepot.com
Ohhhh, hes trying to make his existing hood into a TRX hood...I’m going to go out on a limb and guess that @dodgedifferent2 isn't short a tape measure; he’s short a TRX.
Yes, the hood scoop on the TRX is an actual intake.Ohhhh, hes trying to make his existing hood into a TRX hood...
Well the TRX has a different air intake, so I don't think it will matter.
Doesn't that hood scoop feed into the TRX's intake?
Putting fresh air just into your engine compartment doesn't seem like it will make a huge difference if it's just blowing over the engine. Should get an ram air style intake, and cut the hood to allow air to flow into it imo.
Maybe @Eighty knows or wants to measure?
Sorry I volunteered you.I’ll try to remember to take a measurement in the morning.
Thanks a bunch. This will help alotHere's the measurement. Right at 30" from the back edge of the hood to the front edge of the decal, and about 30-3/8" to the front edge of the rolled metal. It's 30-1/2" to the front of the plastic intake scoop. The camera wasn't perfectly vertical over the scoop, so the measurement looks off in the picture.
