Installed courtesy / running lights
firemedic10584
Central Florida
Took some figuring out for the wiring to get them to work correctly, but I eventually figured it out and now they work as designed. The white courtesy lights override the amber running lights if they’re active. These also have a sweeping turn signal function, but I didn’t want that.
For wiring - use relays. I ended up using a fuse tap for the trailer marker lights for the amber light function. Just use the factory signal to trigger the relay.
For the courtesy lights, I used the footwell light wire (yellow/violet if you have the 3 wire footwell lights) as the trigger wire for the relay for the courtesy lights. Prior to figuring out I needed a relay, the courtesy lights ramping up and ramping down were causing the light strips to flicker / strobe.
Video will be attached below, it’s not letting me upload on my phone for some reason.
Product - OPL5 2PCs Truck LED Running Board Lights Sequential Amber Led Side Marker Light 70 Inch Emergency Extended Crew Cab 216 LEDs Waterproof Flexible Turn Signal Light Bar for Pickup Trucks Car SUV (70in) https://a.co/d/jd9LBGr
