BarryC
 - Dec 20, 2020
lol, Really? The truck is that fragile?I will guess either the front drive shaft or front axle shaft broke.
I was in 4WD, not 4wheel AUTOWhere you in 4-hi or 4-low while plowing? Hopefully not 4-auto.
I'd say either the front differential broke, or the clutches in transfer case
Will do!It does sound like something is broken. However, I would suggest just checking up underneath the front end and making sure there’s not some ice packed around any shaft, joints, or actuators. It probably wouldn’t make a difference but it’s free to check.
Hello,Does it make the grounding sound all of the time, i.e. 4 high, 4 low, 4 Auto and in 2wd?
I see that it was available in 22. It's not anymore. You should be covered. I recall seeing a plow voided warranty, but that was probably my 4th gen.My Truck has a SnowPrep package so “they’re” screwed.
CV joint bearing cage, most likely from front driveshaft.I just found this in my driveway where I lost my 4WD.
Can someone tell me what it is?
Ty!!
