Your dogs are cute.Tazer will do it I believe for up to 35’s
Thanks. The golden isn’t a pup anymore. The brown one is a Chorkie so he’s full grownYour dogs are cute.
Ya they get big fast.Thanks. The golden isn’t a pup anymore. The brown one is a Chorkie so he’s full grown
Tazer works goodi am in the process of doing this on a 1500 but alot of people use the alfaobd app on android devices paired with a obdlinx bluetooth module and jumper harness there are threads all over this site with write ups for it but im not sure that works for 3500's good luck
How can you even plug a tazer into a 3500?Tazer will do it I believe for up to 35’s
Idk I don’t have one. Does this not work?How can you even plug a tazer into a 3500?
They can't get to the security gateway as easy as us with the 1500s. It's inside the dash if I recall what I was reading. In theory they can plug a taser in, if they rip their dash apart.Idk I don’t have one. Does this not work?
If the speed indicated on a phone app can be trusted, my 2021 1500 bighorn recalibrated itself after a couple days of driving.
Ahhh…that explains it. I typically drive around with my phone plugged in, but I took the chord out when I dropped my truck off at the dealership and didn’t bring it with me when I picked it up. Good to know — thanks for the correction.The speedometer can't recalibrate itself. If your phone is connected to UConnect, it will not read accurately.
Doesn’t the phone use the trucks gps when plugged in as well?The speedometer can't recalibrate itself. If your phone is connected to UConnect, it will not read accurately.
That’s what I thought too, but that’s the only time my phone has the wrong mph is when it’s plugged in. After redoing the tire size with Alfa my speedo matches both of my phones, but if I plug one in, the phone that’s plugged in changes to a speed that’s lower than the actual speed. I wish I knew how to make them match so Waze would work rightDoesn’t the phone use the trucks gps when plugged in as well?
I thought so thanksYes. That's what I meant by connected to UConnect.
