Upper Control Arm Tire Clearance
John89
What’s up everyone, I had new tires installed (285/65r20) and the clearance between the UCA’s and tires is real small. I’m needing some input as to whether I need possibly some wheel spacers to increase the clearance or if I should be alright? I would rather not add any spacers..
cskindt
SW IA
If it doesn't touch, then it doesn't touch. Put 1/4" spacers on to make everyone feel better. And it still won't touch by 1/4" more.
theblet
I guess he could just keep an eye on it for awhile and watch for rub on the tires.
6of36
Michigan
I've never looked straight down like that, but isn't the upper ball joint inside the diameter of the rim? I believe it's not as close as it looks from that view. Turn the wheels as far to one side as possible and see what clearance there is from a different perspective.
No, UCA is sidewall level
John89
There’s no rubbing at all, at least none that I’ve heard or noticed, even when doing full turns.
theblet
Might be ok. I’d just check it now and then for signs of rubbing.
jabara572
Atlanta, GA
Mines about the same, I run 1/4" spacers on the front. No issues at all in 40k+ miles. There's plenty of thread in the stock lugs to run the 1/4 spacers.
jdawgjm
Stock? Or lift?
John89
What did you order?
I wanted the fuel mavericks but I saw these and for the price I ended up just pulling the trigger and used the extra money towards amp research power steps.
MO962:
John89
I got the amp research power steps from morris4x4 at a good price with promo code warmup100:
Jeffjad
Southwest PA
MO962:
Can't wait to see pictures. It's hard to find wheels that look good on a white truck. I have been looking for awhile now.
