Realtruck
- Jul 2, 2021
Happy STEPtember 5th Gen Rams!
We are proud to offer a very special deal for you all this month! We have partnered with N-Fab and Go Rhino on this one to bring you some outstanding steps with unbeatable pricing!
Pricing is going to be by PM or email only to take part of this huge sale!
I am going to highlight a few of our top sellers but if there is another N-Fab or Go Rhino board or step that you are interested in please don't hesitate to reach out as this discount does apply to their entire line! We specifically chose these two brands to work with due to the quality of their products and the ingenuity their steps offer
We will be running this special for the month of September, as the name suggests, so do not wait to take part in this limited offer!
(click on the image to bring you to the product page for more info)
Go Rhino D6
Durable steel tube construction with raised hex pattern stepping area
Protected with black textured powdercoat for longevity
Dual purpose design allows D6 steps to function as running boards or rock sliders
Mounts tight for max ground clearance
Optional bolt on 4" drop steps available
300lb weight capacity
5 year warranty
Go Rhino RB20 Slim (Protective Bed Liner Coating)
Constructed from 16-gauge galvanized steel
5.5" step width provides plenty of step-area
Rugged perforations let dirt slip right through keeping board free of debris
Mounts to vehicle's rocker panel
No-drill install
Same aggressive styling as other RB Series Steps
5-year limited warranty
NFab EpYx
Drop down step positioned at each door with 15” inch stepping surface that are 4 inches deep
Modern angular design that fits tight to the vehicle body for a modern clean look
Carbon Steel construction
Two-stage powdercoat finish that provides a sealed, corrosion-resistant finish
5-year warranty on finish and limited lifetime warranty on workmanship
No Drill
NFab RS
Constructed from heavy duty 2" steel tubing
Dual layered black powder coating for superior corrosion resistance
5" wide step plate
Die-Stamped punch plate adds maximum traction
Mounting brackets are welded to the steps
Mounts to rocker panel
5 year warranty on finish and limited lifetime warranty on workmanship
NFab Podium
Sits high and tight to the vehicle
Stainless steel, with a durable black powder-coat finish 1- piece construction
Drop down step design to allow for ease of access on stock or lifted vehicles
4.75” wide
No Drill
Go Rhino D6
5 year warranty
No-drill install
NFab EpYx
No Drill
NFab RS
5" wide step plate
NFab Podium
4.75” wide
No Drill
