Does hitch type affect towing capacity
Ted wilson
I just bought a 2019 2500 limited crew cab
With the diesel engine.
I am trying to get the tow capacity.
I have seen one table that listed a dead tow capacity, distributed hitch capacity. And goosneck capacity.
I have a 2-1/2 tow bar with 2-5/16 ball rated at 21,000 pounds.
So i know that the bar and ball can take the weight.
I do have a distribution hitch as well but line the adjustable height of the other hitch.
So what tow capacity do i have on a dead weight ball?
What if i went to the disyribution hotch!
Ted wilson
I forgot to sadd that it is a 4x4
Sascwatch
I’m not sure what HD towing numbers are, but yes there will be a different tongue weight capacity for weight distribution and standard bumper pull trailers.
The HD forums will probably be more help as most users here are 1500 owners.
Ted wilson
Thanks i will post there
Ted wilson
I have just bought a 2019 limited crew cab 4x4 with diesel. I am trying to figure out the tow weight and how a dead weight hitch and dist hitch change the tow capicity.
I do not plan on goose neck towing. I do have a weight dist hitch someplace but also have the 2-1/2 x 2-5/16 ball hitch that shows the toung weight.
Ted wilson
Hitch type affects load, not the towing capacity.
This site will give you VIN specific towing capacity Ram Tow & Load Capacity
Thanks that one let me do vin lookup
Looks like 16500
I am huessing that the hitch type like a weigjt dist would shift some load to tne front axle.
On my old 2500 that was just totaled i pulled into a weight station several times to check not only trailer weight but axle loading as well.
I was at 12000 pounds and the rear axle still had some capicity left. I forget how mich
I will try to track down the spring bars for my weight didt hitch and may bring it just in case
But i think tne heavy towing is done.
I do have the hitch that shows tong weight,
At one point i saw a chart that had max tong weight listed i wish i could find that
Ted wilson
Thanks. I saw one set of tables that had very small loads for a dead weight hitch ann more for weigjt dist hitch
