Hello guys.
Im new to this forum. I saw it this morning and Im truly desperate for answers. I purchased a 2020 1500 Big Horn from the auction last year. The truck came from Orlando FL. Had some front end damage with the suspension. That all has been fixed. I got the truck back from the body shop at the end the year and once I got home the truck was not turning off after pressing the On/Off button. I even disconnected the battery and it kept running for about 20 mins until it finally turned off on its own.
I replaced the battery on the control. The truck does not open the door with the control. Had to opened it to get in since maybe they did not connect the main handle properly and the key would not even open the car.
I installed a new battery. The mileage (under 20k) shows on the dash but the truck does not turn on. Cabin lights do turn on.
The On/Off switch has a constant flickering of the OFF letters when I push the button but nothing happens. The radio does not turn on, nothing.
The power seats do work, but nothing happens in the dashboard. The new battery was dead after 4 or 5 days. Went and exchanged it for a new one. Checked the voltage on the new one and everything.
I read about maybe needing a bigger battery. I purchased a 24F from Walmart. Around 550 CCA. I even used a portable jumper on it with the battery and nothing.
I have no clue what to do. The car is salvage so no warranty at all. By the way I know the car did not have any water damage. Purchased the car in the summer.
In in Miami area. Any advise will be highly appreciated or if anyone knows an electrician or Ram mechanic please let me know.
Thank you all for your time.
