After-Market Differential Covers
jgc650i
North Carolina
I have a 2022 Limited with the e-Locker. Thinking about possibly swapping out the Diff Covers and wondering what others have selected for those who have swapped. would appreciate any feedback and/or pics of what you’ve gone with and why. Also, I’m familiar with the testing Banks did on various flat vs rounded diff covers, so no need to repost that vid in this thread. Thanks in advance for any feeedback, much appreciated!
jgc650i
North Carolina
Bumping this up one last time to see if anyone else has any feedback. Even though it failed miserably the first time, I’ll say again. . . “I’m familiar with the testing Banks did on various flat vs rounded diff covers, so no need to repost that vid in this thread.”
Many thanks!
cskindt
SW IA
Many thanks!
What's wrong with the OEM cover?
After watching the Banks videos, why not just go with one of theirs?
Because they don't make one for the 1500s. I will wait to see if they ever do. Other than that's will stick with OEM
cskindt
SW IA
That's a good reason.
Is there anything to be gained by other options?
Scram1500
Check out PPE, they caught my eye when looking for aluminum transmission pans
Looks mostly. If you watched the Banks videos then you know the downfall of using jher styles. I have a MagHytec cover on my Dakota. Looks cool, has a drain plug and "dip stick" to check fluid level that the factory cover doesn't have. Also uses an o-ring gasket for sealing, so no silicone mess. Holds about 1/2 qt more fluid
Rick3478
NW OH
Improved oil cooling due to finned aluminum. Improved strength and stiffness due to cast cover. Improved fill and drain due to threaded plugs instead of rubber bung. Some even have bolts that add support to the carrier bearing caps, though I'm not sure how effective or necessary that is. And they look cool.
