I waited for Belltech to release their kit for the 5th gen Ram for at least two years. It's finally here as of a few months ago in several flavors and options.
1060SP
2/3-4 drop using lowering spindles
1060SPS
2/3-4 drop with lowering spindles and swaybars
1061SP
An adjustable kit that gives you 1-3/3-4 using struts rather than spindles
1061SPS
An adjustable kit that gives you 1-3/3-4 using struts rather than spindles and swaybars.
1062SP
3/5 drop with spindles and adjustable struts.
1062SPS
3/5 drop with spindles, adjustable struts and swaybars.
1063SP
3/5 drop with adjustable struts.
1063SPS
3/5 drop with adjustable struts and swaybars.
1061HK
1-3/3-4 drop with performance coilovers in the front and swaybars
1061SPC
1-3/3-4 drop with performance coilovers.
1062HK
3-4/4-5 drop with performance coilovers and drop spindles with swaybars
The list keeps going and you get the idea. They have a wide selection to choose from depending on your requirements. I'll be covering just the 1060SP kit here.
The vehicle the kit went on is a 2021 Ram 1500 Lonestar, 2wd, crewcab shortbed with the 5.7 engine.
Control Arm install instructions.
1060SP
1060SPS
1061SP
1061SPS
1062SP
1062SPS
1063SP
1063SPS
1061HK
1061SPC
1062HK
