Side mirror question.
stancedeuros
on mine it is fixed and USELESS. If one could turn adjust it it could be usefull, I put a $2 round adjustable one over it
Agreed. If I could move it down a little to be able to see parking lines when backing in, I would love it. I've added adjustable ones on every other truck due to that one need.
Liquid Li0n
Belgium
my Limited does blind the 2 outside mirrors, but not the small piece on the mirror unfortunately.
KCURTMAR91
Yep, me too. FWIW you can (on my model at least) set the mirrors to tilt down to see the rear wheels automatically when in reverese, but there does not seem be any adjustment of how far they tilt and for me they tilt too far so I turned off that feature
dustinb80
Newby to this forum, but not forums in general.
Just got my 2023 Ram 1500 Limited about 2 weeks ago. Went with the Night Edition which lists having "Auto Dimming Exterior Driver Side Mirror". Odd to me that they dont do both mirrors on the Limited package. Even my 2019 Laramie had them both. Anyways, chose the tow mirrors, not knowing that by doing so I would lose the dimming feature. W/ the tow mirrors, I dont have the option of adjusting the "Spotter" mirror, again odd. I just sold my 2020 2500 Laramie (Traded in the 2019 1500 b/c I was now towing an RV) and it had a button to allow the adjustment. Frustrated b/c now I dont have dimming exterior mirror(s) nor do I have the ability to adjust the spotter mirror on the tow mirrors. B/C I drive to work so early in the morning, the dimming feature is more beneficial to me than the tow mirrors. Working with the dealership now to iron this **** out.
Darksteel165
Massachusetts
My 2022 limited has both dimming.
The 2023s they removed a bunch of things because they think we aren't paying enough.
Darksteel165
Massachusetts
I double checked and redid a build, added the "Red" package, has both dimming mirrors. F*ckers
I wanted the red things but I don't want to be involved with anything that is from Bono.
I also don't need "TM" after the word Ram.
Oddly I don't see how you are adding the red package since it's not offered on the 2023s? At least not showing for me.
On 2023 it says the night edition adds ($4,145)
  • Automatic-Dimming Exterior Driver Mirror
Night edition on a 2022 it adds ($3,995)
  • Automatic-Dimming Exterior Passenger-Mirror
Less features for more money.
dustinb80
I see that as well, but it is available on the TRX level
Eighty
Moderator / Dream Killer
I have found three build sheets (for 2023) that list "(Red) Edition".
Trippi
Macedon NY
The Driver Dimming mirror is standard on the Limited not sure why it's even listed as an addition with Night Package. This from Standard Features on the build site.
St-na
Houston
I have both my mirror with dimming, but I tried to switch dimming off, just to make sure it's working. I fill no any difference between on/off. I have a filling that they are always dimmed at night. Any other way to check this function?
vincentw56
Put black tape over the mirror sensor facing the windshield. It will dim even in daytime.
St-na
Houston
Passenger side dimming not working, I have recently replace this mirror with all the functions, including dimming. What can be the reason?
Darksteel165
Massachusetts
My side mirrors don't dim at night until the light input is very high.
Are you sure that works covering the review mirror for the sides?
I have been on the highway in pitch black and my side view mirrors will not dim with some headlights, but others it will dim (you can tell by the outside edge of the mirror)
St-na
Houston
I have covered the mirror sensor by finger and clearly noted cabin and driver side mirrors dimming. It's very clear, both became very dark, no any reaction on passenger side.
Darksteel165
Massachusetts
Interesting. I just drove home and it's dark and both of my side view mirrors did not dim, but I know for a fact they work.
Sounds like you either don't have it connected, or have the wrong glass installed, you can pop off the glass and check the connections there are 4.
vincentw56
Yep, I know it works. When I installed my comma on the windshield, it caused it to stop working. My work around was to put the tape over it and control it manually through the settings.
vincentw56
I do not know unless there is a setting in the BCM that needs set.
St-na
Houston
Had the same suspicious Yesterday. When I am driving at night, I see no differences between all 3. Wouldn't say it's bad, quite comfortable, unless someone right behind me with very bright headlights. I do not like very much idea with the tape, will try attached solution.
