TN47361
- Nov 24, 2018
Waiting lolI have not yet tested my garage but will do that today to see if it fits. I am hoping it does. My garage is exactly 7 feet.
I hear ya. Work all day, kids at night. Gotta clear out my garage. Will do this weekend.Waiting lol
Shovel your driveway.....problem solved......Looks great! My concern seeing how close that is, if it will work here in Michigan when I pull in to a driveway full of several inches of snow lol
Did you measure your wheel hub to guard lip before deciding on the full kit (i.e. installing the pre-load spacer)?I put the 3.5 inch readylift on with the off road package. Very happy with the height. DId not want the 6 inches as that wild be too high for my garage.
It isn't so much the UCAs you have to worry about as I believe the ones from Readylift are good up to 5 or 6 inches. The problem is the steering angles and more importantly, the CV joint angles. If you use much 4wd, your risk of damaging something increases big timeDid you measure your wheel hub to guard lip before deciding on the full kit (i.e. installing the pre-load spacer)?
There’s a lot of talk about the extra inch and how it affects the UCA’s and geometry of the front end. Mine should be getting installed next week but trying to decide whether or not to do the full kit.
Wow great plan lolShovel your driveway.....problem solved......
I did none if that.Did you measure your wheel hub to guard lip before deciding on the full kit (i.e. installing the pre-load spacer)?
Looks Great! Can I ask what you paid in labor costs?So I gotta say, the pics do NOT do this truck justice. I wasn’t sure how it would look once installed but it is even better than I hoped. Not too tall but no longer short. Does not look anything like a stock tuck. Few pics attached. will take more tomorrow. Rides great as it did before as well. No loss whatsoever in power. Will measure and report. FYI, wheels and tires are 35x12.5x18.
Bottom line, best looking truck I have ever owned and this is my third lifted Ram 1500.
About $500 labor costs.Looks Great! Can I ask what you paid in labor costs?
I had a shop do the lift, so really, really easy. But the lift itself is pretty easy.Looks good. How difficult was it to do
I have the off road package and put on the 3.5 inch lift.Did you put the full 3.5 inch kit on in addition to the Off Road package? Yours looks higher than mine, but I was told to only go 2.5 in the front with the Off Road package.
Your truck looks great. I came real close to getting the same color you have.
Factory steps.Great looking truck, did you install the retractable steps or did they come installed? Can you post a pic with them deployed? I want to add the Mopar's 2" lift but undecided on the the step bars yet. I like to go a little offloading so I don't want any that hang down too low.
