Extended fender flares for Rebel?
ALT_F13
Seattle, WA
Anyone find an OEM look flare that fits new rebels yet?
Same here - I don't like the look of rivet fender flares. My oem fender flares are all scratched, plus with TRX wheels I need wider flares. Couldn't find anything that fits Rebels.
ALT_F13
Seattle, WA
I've got an update from Bushwacker:
"Thank you for contacting us. Unfortunately the Pocket Style is the only option as this is the most popular flare. See no plans for the Extend-A-Fender to be offered for the Rebel Model."
So Bushwacker pocket style fender flares are the only option for Rebel, and we shouldn't expect that to change in the nearest future.
Big-A-Rob
Has anyone tried out these Air Design Super Bolt Fender Flares: Super Bolt® Fender Flare Set
According to the response from the manufacturer they do fit the Rebel. They are pricier than the Bushwacker Pocket Style but the bolts are a little bit more than just style.
RebelWraith
Polymath
Montclair, Va.
Unless they came out with a new model they do not. The front trim piece under the headlight on the Rebels is shorter (not as tall) as the same part on the other Ram models. So, the front fender flare would need to be shorter in that area.
Tommyboy59
Just installed Bushwacker on 2020 Rebel, worked great, fit over stock flares. Just remove bottom plastic and covers most. Great look.
REBELmtnbiker
Now you need to get bigger wheels and tires to fill up those arches. They look out of place right now. I just don't like rivets or bolts on flares.
Tommyboy59
Pink and black they all have the Rivets. you’re welcome the same size although next tires, I’ll get 2” bigger. Still want the factory warranty don’t want to ruin that. Took out the seven year unlimited mile warranty, well worth it.
VRAM
Has anyone found extended flares that will fit a Rebel? Bough my truck with a lift and 35x13.5s. The factor flares don’t protect the body much at all. All of the flares I can find say they don’t fit the Rebel. Any help? Thanks
I've been looking for a while now too and I can't seem to find any that will fit the rebel...
