lapoolboy
 - Mar 5, 2022
Can you elaborate on how to determine if I have the wires at the rear X670 plug? Which wires am I looking for? I've read that I can order just the two lights themselves and the two short harnesses instead of the complete kitI bought the Mopar bed light kit for my Lonestar. The instructions have you run the wires to the front and into the cab by cutting a rubber grommet and adding the wires to the plug at the BCM. I had the wires at my rear X670 plug so I shortened the Mopar harness and added new terminals and plugged it into the plug. Then I used AlfaOBD to program it.
...I'm trying to make this as simple as possible.
Of course, the LineX guys sprayed over the blank plugs where the lights go, so I'll have to figure out how to cleanly get them out while still allowing the lights to clip in.
