Blue Streak Ram
- Jan 6, 2019
Looking for opinions on the 2 ohm CDT Audio 6x9’s for the front doors.
What do you have for factory system? I know the Alpine uses 3-ohm speakers. I have the 3-ohm CDT Audio speakers in my front doorsLooking for opinions on the 2 ohm CDT Audio 6x9’s for the front doors.
Are yours amped separately or just using the factory amp?I love them. I have them in the front and they are way better than the infinity and OEM. I have the Alpine system.
FactoryAre yours amped separately or just using the factory amp?
What do you mean by tuning?I have a pair of CL-69SUB in the front doors, with 75W per channel. Originally has the CL-69, and these are great. But, tuning them makes all the difference in the world
Got it, thanks! Went ahead and bought them.equalizing, but At a much more detailed level (you need a dsp to do this). You can tune Out the distortion, and for mid-bass specifically, smoothing the transition from sub to mid bass speaker has a big impact on the mid bass speakers’ performance.
Did you install a DSP? I’ve been looking at doing this in my truck but am unsure what one to get for the HK system.equalizing, but At a much more detailed level (you need a dsp to do this). You can tune Out the distortion, and for mid-bass specifically, smoothing the transition from sub to mid bass speaker has a big impact on the mid bass speakers’ performance.
I had a Helix V8 dsp/amp in my 2021 Bighorn with the Alpine system, but wasn’t able to get it out prior to trading in. eventually, I’ll get another Helix for my 2022, which has the HK. There are quite a few options out there, Helix is very well regarded, and worked Perfectly for me.Did you install a DSP? I’ve been looking at doing this in my truck but am unsure what one to get for the HK system.
So you fit the regular CL 69 speaker and not the slim one in the doors?I have a pair of CL-69SUB in the front doors, with 75W per channel. Originally has the CL-69, and these are great. But, tuning them makes all the difference in the world
I just checked my receipt. I have the slim one now (CL-69S), but previously had the CL-69SUB, which is deeper. I put a 1/2” spacer on it, and it fit just fine-probably could have used 1/4” or lessSo you fit the regular CL 69 speaker and not the slim one in the doors?
Would you say the regular sub or the slim one performed better? I was going to replace my current setup with a couple pairs of theseI just checked my receipt. I have the slim one now (CL-69S), but previously had the CL-69SUB, which is deeper. I put a 1/2” spacer on it, and it fit just fine-probably could have used 1/4” or less
Awe got it. I would just be using it in place of my infinity ones with the HK system that I have currently so no DSP or aftermarket amplificationthe sub was better, IMO. But I was running a 3-way active system, so could really fine tune it, and had it crossed over very low
