Battery Terminal Insulator Cover —- see photo, lower right-hand corner — red plastic cover for positive battery terminal. Where I can get an OEM?
Dealer would be your best bet, or through any place that sells Mopar replacement parts like @Accessory.Parts would just need part number
RHCan
USAF Retired Vet
North Texas
I too looked for this part. Dealer stated it was only sold with the positive battery cable as a complete assembly.
RBJ
VA.
Thanks for trying to assist. None of the positive battery terminal covers at any of the links provided as suggestions are a OEM replacement, as shown in the picture I provided. My search continues. Thanks nonetheless for your input.
RBJ
VA.
See lower right hand corner in photo. It shows the red plastic positive battery terminal cover I’m searching for. D2B9FD4F-930F-4CED-8B3F-516833E8A523.jpeg
RHCan
USAF Retired Vet
North Texas
I will have my dealer order it and reply back middle of week
RBJ
VA.
I believe it is
68504630AA​
Yes, you’re correct. Your second post at 7:55pm is the correct OEM part (68436638AA) I needed, not part number 68504630AA.
Thanks Sacscwatch!
Sascwatch
Yes, you’re correct. That is the correct OEM part I need.
Thanks!
There seems to be two different covers, I’ve posted both part numbers and your dealer can cross check them to your vin to make sure you order the correct one.
