Yes, you’re correct. Your second post at 7:55pm is the correct OEM part (68436638AA) I needed, not part number 68504630AA.I believe it is
68504630AA
There seems to be two different covers, I’ve posted both part numbers and your dealer can cross check them to your vin to make sure you order the correct one.Yes, you’re correct. That is the correct OEM part I need.
Thanks!
Most of those Mopar sites are just CDJR dealers. That one is Thunder Chrysler in Tampa, FLI found the OEM part and it was delivered in 2 days from:
www.factorychryslerparts.com
I recommend this company!
