We’re talking about where to plug the security by-pass into aren’t we or did I miss read the OP’s post?
Here’s what Koadtech says about connecting their Security Bypass Module.
Sounds like there are some semantics to deal with. He asked for the gateway plugs (so he could bypass them). The black ones are the gateway plugs.
You're talking about a specific harness that bypasses security using the canbus and OBD II (I'm not really familiar with that harness or what it's for).
Here's a snippet from the Tazer DT manual, showing the security gateway plugs.
LOL gotcha. have it done at a dealer, or aftermarket?
aftermarket. Had the same place the dealer sends their stuff to. It was 45 min away but very happy with the job.
Thanks all, I found the bypass and I now have auto folding mirrors. :p:D:D:D:D
Have no Idea how to up load video? But Love them.
Like... you put the truck in park and they go in automatically?
Got these Suspension Maxx front sway bar end links in for leveled trucks. Not too bad, but getting the OEM ones out was somewhat annoying.
I guess I misunderstood what he was trying to do. Thanks for clarifying.
The cable I mention is a security bypass module for use with AlphaOBD to allow you to make changes to the BCM.
The security bypass cable for AlfaOBD plugs into the black block, not the white ones.
Swapped out the chrome emblems for black ones. Did all except the hood badge. I think I might just leave it.
I’m having my sidesteps sprayed with Rhino Lining tomorrow and black exhaust tips are supposed to be delivered tomorrow as well. That’s it for a while!
7239A2C5-CD49-4E86-9DB1-80FD5A15D52A.jpeg1C3D62BF-7DF5-4204-8143-63BD1A8DCE8C.jpegCB1430AC-4EDD-4221-A135-F63AF30B38CA.jpeg97A5B118-1695-4D4F-B133-EF35A515B1CB.jpeg
Easiest way to test would be to put power to the wire before installing them in the truck and see if the DRLs come on with nothing else connected. Would obviously need a ground as well
yeap
i would test it that way if he has tools/ stuff for him to feed power and ground. if not then just connect all the harness other than the fuse tap and key on.
yeap
I mean, if he has the tools to install the headlights he has the tools to test the wiring.
But the Power Wagon actually has a lower payload & towing rating than the 1500 though..? Doesn’t it?
Depends on how the 1500 is configured, but it's absolutely possible. I'm usually a strict numbers capacity guy while towing/hauling, but with a bigger chassis, the 6.4, and 4.10 rears, I'd still take the power wagon regardless of the numbers if I could. That diesel 2023 model really has my interest, but whew! That price tag.
Going with a relay, the button switch I'm using is too small to handle the current going though the fuse tap
  • Back
