FAQ: ECO light
dswoboda2120
Wisconsin
This FAQ addresses the issues on the forum concerning the ECO light.
What is the ECO light?
The general consensus on the forums is that the ECO light only indicates when your engine is running in Multi-Displacement System (MDS) mode, and the status of this light doesn't affect the engagement of the MDS mode.
Where is the ECO light?
It is located on the upper left of the dash instrument cluster. Lights up ECO in green.
How do I turn the ECO light on/off in the settings?
This is done through the Uconnect system. Go to settings, then look under display. The option is called Fuel Saver Display in Cluster. Check the box to have the ECO light display in the cluster when in Fuel Saver mode.
Fuel Saver Display in Cluster is checked, I still don't see my ECO light.
The forum, at the time of writing this FAQ, doesn't have a definite answer to this. Some say there is a break in period and you will not see it for a few thousand miles. Others say they see the light right from the start of ownership. The majority seem to believe it is based off your personal driving style and conditions such as towing, hauling, hills, etc.
grinch72
Interesting consensus. The FAQ for most tuners indicate that the ECO light is NOT associated with the MDS kicking on although I would tend to agree with the forum consensus and think that it is. Has anyone gotten any kind of confirmation either way from FCA?
Jello0123
I have the eTorque and have been seeing it since day 1. It will come on even in acceleration (light acceleration) and when coasting. I haven't seen it much on the highway, maybe up to 65mph. I would assume it is on when the MDS is activated as I feel a drag when it is on and a pitch change. Same thing happened on my old Silverado with Active Fuel Management. Very similar experience.
Raydar
Carrollton, GA
I have under five hundred miles on my truck, and since I enabled the indicator, it comes on regularly - usually during a steady state cruise, or coasting.
Sometimes I can hear the change in exhaust note, too.
wwalljr
Right Here
^^^Same here. Been seeing it since purchase.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
No confirmation, but I've seen the light every day in my first 7,000 miles, and it has never come on separately from MDS.
timtlu
Mine was off from dealership, but once turned on, I have regularly seen it kick in and out for the last few days.
