2wheelsonly
- Nov 23, 2022
So I want to install an aftermarket amp, was going to remove the negative cable off the battery and then bolt the amp power cable to the positive. This is a used RAM so I wouldn't know the radio theft codes...I know these RAM trucks take a few hours/days to relearn the systems after the battery gets disconnected.
What should I expect when removing the negative battery cable on these 5th gen trucks?
