Installed the low profile hood protector today. Didn't realize at first it was going to be a stick on but went with it anyway. Fairly easy install. Just place it, mark with tape and lift it off. clean with alcohol wipes and provided cleaning cloth. Then pull an inch off 3M tape underside and place on hood, line up and pull backing off as you press down. It was a little bit of a PITA to line up solo but got it done. It's cold out so I used a hair dryer to heat it up a bit as I set it.
Sent from my SM-A136U using Tapatalk
