Thank you!It was discussed in a previous thread that the sport hood has the holes under the vents, but the hood liner covers the holes and the bottoms of the vents are solid. You’d have to put holes in the plastic vents and cut into the hood lining. Not sure what benefit you would gain, and that would probably be offset by your engine bay becoming filthy.
Post in thread 'Hood vents even more useless than we knew'
I was wondering if they actually made changes to the hood for the G/T model. I’m guessing not. False advertisingIt was discussed in a previous thread that the sport hood has the holes under the vents, but the hood liner covers the holes and the bottoms of the vents are solid. You’d have to put holes in the plastic vents and cut into the hood lining. Not sure what benefit you would gain, and that would probably be offset by your engine bay becoming filthy.
The hood for the GT package is the same sport performance hood the Rebel comes with. And the same hood you get with certain options on other models. False advertising if they are saying it's functional.Thank you!
They don't claim the increase in HP probably because there is none. Unless they did other enhancements to the tune and engine, a cold air intake doesn't give you any real benefit. You might get a perceived benefit, but there is not actual evidence it does anything.I mean it doesn't exactly say the vents are real.
The GT package comes with the Ram Air style intake which would improve airflow, but that actually goes through the front grille.
The large "vent" by the windshield is solid plastic.
The other 2 "vents" do have a water drain hole, but they are not going to make your engine cooler or anything.
They don't even claim the GT model has increased HP or anything even with the different style air intake which should give it more. They are being rather modest if you ask me.
The Vararam has dyno proven HP increasez and I personally tested 0-60 times and got a verified decrease in 0-60 over stock with my Vararam.They don't claim the increase in HP probably because there is none. Unless they did other enhancements to the tune and engine, a cold air intake doesn't give you any real benefit. You might get a perceived benefit, but there is not actual evidence it does anything.
Well, that is what I have, can't say I personally noticed any improvement. I just like the way it looks. You know, for those few times I open the hood.The Vararam has dyno proven HP increasez and I personally tested 0-60 times and got a verified decrease in 0-60 over stock with my Vararam.
Main reason I got mine was for looks as well.Well, that is what I have, can't say I personally noticed any improvement. I just like the way it looks. You know, for those few times I open the hood.![]()
The stock air box is a cold air intake...They don't claim the increase in HP probably because there is none. Unless they did other enhancements to the tune and engine, a cold air intake doesn't give you any real benefit. You might get a perceived benefit, but there is not actual evidence it does anything.
