Auto heated seat issue
theRamguy
So a little background. I may have changed a setting with alfaobd with regards ro the auto heated seat. It is set to enabled but it does not turn on when under 40 degrees. I have to manually turn it on. The auto heated steering wheel however does turn on.
Any idea as to what may be causing the heated seats not turning on on startup but working?
I posted this here because the auto comfort settings are part of the uax 12 in system.
Make sure you have it enabled in your radio settings.
Have you tried doing a search for seat or heat in AlfaODB? This is why you should always do a backup before you make changes. ;)
Backup was made and I've changed everything back and it isn't working
So, has to be below 40F? Mine doesn't work either but maybe that's why.
