Huge decrease in MPG
btripp31
My last 2 tanks of gas I have noticed a 4ish MPG decrease. Does anyone have any thoughts on why?
Mine goes down every time cold weather hits due to using the remote start and letting it idle to warm up more than usual. I don’t think it’s down 4 mpg though
Cold weather + decrease in tire pressure. Mine dropped 5 psi with the recent cold snap. Really affects gas mileage driving with under inflated tires.
mine dropped this past week due to extremely cold temps (below zero). It went from 17/18 to 14/15. Suppose to ”warm back up” (20’s) later this week.
I'll check the tires, not much I can do about the cold
Winter fuel for sure and you have to keep check those tires as the cold weather comes in and then again as the weather warms up in the spring as you will need let some air out. I will say that since the pandemic it seem like the loss in MPG in the winter seems to me to have been worse than before. It seem like I have seen a bigger drop in the last couple years at winter time. New blends?
